Question about Fargo DTC550 Thermal Card Printer
My fargo printer dtc550 has a HEAD LIFT ERROR AND CAN NOT PRINT HELP ME OUT
    Sergeant:
  • 192 Answers
Http://badgepros.com/2011/idprinters/fargo/check-lam-error-fargo-dtc550lc/
HiI hope this link will be of help to youKing regardsMichelle
Posted on Feb 23, 2012
SOURCE: i am using fargo direct
In this problem , first check the front side head lift gear and gear belt.
solution : Gear or gear belt may be broken.
by
LAKSHMI KANTH,
CHENNAI.
Posted on Sep 05, 2011
SOURCE: bad print heads
This is a continuing problem we have with our Fargo DTC550 printer. If you remove the printhead from the printer and look at the underside you will see a nick on the head in the same area you are getting a line on your card. Fargo claims we damaged the head due to not keeping the printer clean even though we clean at every ribbon change. I believe that the damage happens when a plastic debris (from the plastic card) gets between the card and the head. You must check your card stock to make sure there is no plastic debris on them. Bottom line, you have to replace the head and at the time it costs $700 per head.
Posted on May 05, 2008
SOURCE: Fargo DTC550
My printer is Fargo DTC550 and I'm using HID 1326 card for printing. I cannot get this equipment to function correctly. I had no
problems installing the software and hooking up the printer to make the ID
cards, but all attempts to print an ID card have failed. Every card I have
tried to make has been unsatisfactory, with colours not printing, very poor
image quality, and the lamination device consistently jamming for every
single card I have tried to make.
Sir, please help me.
Showkat
Posted on Oct 04, 2008
SOURCE: FRAGO DTC550 ID MACHINE
hello my problem always the ribbon is broken, wath can i do to solve this.
please help me
Posted on Feb 11, 2010
  • 6 Answers
SOURCE: DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Posted on Apr 06, 2010
Fargo dtc 550 head voltage error
Fargo DTC550 Head Lift Error - YouTube
? 4:46
https://www.youtube.com/watch?v=1MCO3wHmLgE
Jan 8, 2015 - Uploaded by Alfonso Terrazas L
Fargo DTC550. Head Lift Error. Este error se origina porque el O-Ring que hace girar el engrane que ...
Mar 22, 2017 | Fargo Office Equipment & Supplies
Printer head error
Try updating, or reloading, the printers firmware using the "Fargo Workbench application. it can be found (along with the firmware file) in the "Downloads and Drivers" section, in the Support tab on HIDglobal.com.
Print head errors come in a few ways. Some common issues i see are:
"Print head voltage error"
1. The wire harness, from head to pcb, is loose or damaged.
2. Print head is Damaged and needs replacement. Usually you will see dull lines going straight across your final prints, consistently.
"Head life error"
This error is primarily a mechanical failure. the belts that drive the head life motor have worn, and need replacement.
Apr 24, 2014 | Fargo DTC550 Thermal Card Printer
I am using fargo direct to card 550 printing machine.In that error displays "HEAD LIFT ERROR". sir how can i solve this problem and also have lots of noise is coming from the printer..please...
by
LAKSHMI KANTH,
CHENNAI.
Aug 02, 2011 | Fargo DTC550 Thermal Card Printer
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
Error/ Head Lift Error
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Bad print heads
Apr 30, 2008 | Fargo DTC550 Thermal Card Printer
The is usually resolved by replacing the head lift motor or sensor.
Dec 17, 2007 | Fargo DTC550 Thermal Card Printer
Fargo DTC550
Showkat
Nov 26, 2007 | Fargo DTC550 Thermal Card Printer
Fargo DTC550 Thermal Card Printer Logo
1,195 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
