Paper jam (j44 and j43) on panasonic workio dp 180 copier
4 Suggested Answers
MitchSchaft
  • 25 Answers
SOURCE: getting J33 code on panasonic workio dp-2500
That's a registration sensor error. 9 times out of 10, the registration sensor's spring fell out of place and that sensor is not popping back. When you open the right door, you'll see a sensor flag (plastic flag) sitting in the middle of a rubber roller.
Posted on Jan 25, 2008
  • 18 Answers
SOURCE: Paper Jam
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Posted on Nov 27, 2008
  • 9 Answers
SOURCE: Workio DP-1820E Copier: Can anyone tell me how to clean a workio 1820 phot...
the copier can't be cleaned. The opc drum needs to be replaced so unfortunately its gonna cost you some moola
Posted on Jun 05, 2010
Panasonic Workio DP-8060 j50 problem
Check/replace the three exit and inverter actuatiors part #'s dzkl000047/48/49. Make sure inverter guides are tight. If persists replace inverter solenoid part #dzgb000033.
Jun 19, 2014 | Panasonic DP-8060 Copier, Workio DP8060...
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
Getting error j43 on workio 190, but there is no paper jam
yep
it is common error for dp-180/190.
and the usual cause of that are worn out 2 bushings of heat roller
what you can do with that is to clean the fuser unit esp. the bushings of heat roller.
well off course the safest way is to replace the whole fusing unit.
that's it. :)
Feb 08, 2010 | Panasonic Workio DP-190 Multifunction...
PANASONIC WORKIO 180, good morning, my printer
Thank you very much for requist, First time follow my tips.this problem is carry on Fuser unite.heater lamp fuse or fuse is burning,change thermostate.
Dec 09, 2009 | Panasonic Workio DP-190 Multifunction...
Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
Oct 04, 2008 | Panasonic Workio DP-190 Multifunction...
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
Good Luck
Sep 27, 2008 | Panasonic Workio DP-4530 Copier
My Panasonic DP2500 copier
remove paper jam light stuck on, but there is no paper jam
Apr 17, 2008 | Panasonic Workio DP-2500E Copier
I have a Panasonic Workio DPCL21 color laser printer with "Jam 1"
If no paper can be found, most likely a stuck lever in the paper path. Sensor lever may have been dislodged during a jam removal.
Dec 03, 2007 | Panasonic Workio DP-2330 Printer
Panasonic fascimile paper jam
pleaz check the paper path sensor any of them is not working or small piece of paper can be there
Aug 17, 2007 | Panasonic Workio DP-4530 Copier
149 people viewed this question
jasbo
jasbo
