Question about Fisher and Paykel Washing Machines
How to fix a fisher and paykel pride 5.5 that beeps and didn't cyle?
  • Fisher and P... Expert
  • 554 Answers
Here is a service manual,
you will need Adobe reader to view PDF's
http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
Posted on Dec 26, 2013
  • 1028 Answers
SOURCE: Fisher and Paykel Pride 5.5
sure lean washer back against wall diverter valve on bottom rear next to pump probably just clogged with lint
Posted on Jul 05, 2008
SOURCE: Fisher & Paykel Pride 5.5 Smartdrive 8 not spining
hi as a guess there is some stuff caught between the magnet of the motor and the windings. if u unplug the machine open the inspection door and remove the magnet part and clean it it might help
Posted on Aug 05, 2008
SOURCE: Fisher and Paykel Pride 5.5kg
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Posted on Jul 06, 2009
  • 69 Answers
SOURCE: How to I get to the pump on my Fisher & Paykel
If machine has water in it, bucket out as much as you can.
To access pump:
-Pull machine forward and lean it backwards so you can access under machine.
-On the front right hand side, you will see a fan blade- this is the drain pump. This fan blade should spin freely if you turn it by hand.
-To remove pump: remove plug connection that has 2 wires. Remove other plug connection that has 1 wire. On the top of the pump assembly, you will see a white plastic tag, about a 40mm long horizontally across the pump- gently pull tag towards you, and turn complete pump unit anti clockwise- whole pump will drop out (don't force it, it should come out easily) *Note* if there is water in machine still, it will come out when you remove pump assembly- be ready with some towels!!
-Check pump impellor(blade on other end of pump) is free from obstruction, and turns easily. Check with your finger to see if there is any obstruction in the hole where the pump has come out of (inside bowl).
-You can test pump with an ohm meter (should be approx 37ohms from memory)
Reassemble and test for leaks etc
Posted on Aug 11, 2009
  • 4088 Answers
SOURCE: my fisher and paykel pride top load washing machine
Sounds like timer/controller is having problems--replace same.
Posted on Aug 14, 2009
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
My Fisher and Paykel Pride 5.5kg washer will not start it's cycle? All the lights come on but it will not start? No beeping? Can anybody help me?
it could be a reed switch (lid sensor) located under right hand side of hob under lid ...this may solve your problem
Feb 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel Smart Drive 9, pride 5.5 turns on by itself and beeps
Probably a bad controller. Note the lights that are illuminated and call F/P.
Jul 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
Aug 05, 2008 | Washing Machines
There is a transmission clutch that engages for the spin cycle. A gear has worn or broken a tooth. Replacement of the transmission hispeed spin cycle assembly is required.
The other comments are of no use. You must get parts from an Authorized Fisher & Paykel dealer, or have an authorized repairman service the machine.
Aug 04, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
54 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
