Question about Electronics - Others
My inverter shows overload and battery low when i switch something
3 Suggested Answers
nitrospawn
  • 290 Answers
SOURCE: inverter keeps showing overload red led when its
if there is no short circuit any were then the overload control may be bad
Posted on Feb 26, 2010
  • 41 Answers
SOURCE: numeric inverter battery low
you have to replace your inverter battery. also numeric is waste brand in ups and inverters. go for apc brand for inverters and ups. their battery will last nearly 3 to 4 years in perfect condition.
Posted on Apr 11, 2013
My inverter shows overload with no load
I've had a couple of inverters do that. In both cases, one or more of the switching transistors, or scr's, went bad. If they short, the unit will show overload.
Feb 03, 2017 | Inverter Electronics - Others
Tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual.
E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models.
E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units.
E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently.
E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.?
E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation.
E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power.
E-07 Triac control error Triac has overheated. Shut down unit and allow to cool.
E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch.
E-09 Spare
E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000.
E-11 Spare
E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1.
E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual
E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition.
CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed.
OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
on May 14, 2015 | Xantrex Technology Electronics - Others
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
How do I fix or reset my inverter?
Low input voltage or current.
Bad input voltage sensor.
Test by connecting directly to battery (with jumpers or make an adapter). The wiring or connection to your power port (cigar lighter) may be bad.
If it works at the battery, it is the car wiring. If not, it will cost more than the 25 dollar price tag to have it repaired. Just replace it (tryhttp://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter )
Aug 11, 2014 | Powerline 0900-73 Slimline Inverter
Overload indicator comes on without any appliance attached
The battery may be new- but how much charge does it have? The inverter has a high and low battery warning.
If the inverter has no load upon it, it may see the battery potential as high. so if you put a load on it such as an incandescant lamp, in parallel to the inverter, and as an inverter load it should circumvent the warning. Then it is a matter of fine tuning the setup.
Dec 29, 2011 | Electronics - Others
Freedom 20 Inverter/Charger Overload will not reset.
When I switch my Freedom inverter on it shows E02 fault Low battery voltage. I have had the batteries tested and they are okay.
When I plug into the mains to charge batteries the Chrgeheart interphase shows charging light but nothing happens No current.
If anyone could advise I would greatly appreciate it. Thanks
Ian
Dec 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Overload prblem of inverter
every thing is working fine, the battery shows 13.28volts, the Mosfets are good, cant understand still why the hell it shows overload, without connecting any load to it, give me a reasonable solution if any one can.
Nov 13, 2009 | Inverter Yaskawa F7 Drive
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
UPS problem,inverter getting overload
did u refill ur inverter
its happens too me too sometimes
"can u rate me, for my work... please"
thanks
May 17, 2009 | Powerline 200Watt DC to AC inverter...
Electronics - Others Logo
501 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
