Question about Frigidaire ATF6000ES Front Load Washer
Fridgidaire front load not starting
Went to start another load (been washing all day) pressed "start" and door locked, but water never started. After about 10 secs. the entire panel blink followed by three beeps. While beeping the vertical right side status panel (door lock, wash, rinse, spin, etc) flashed a couple of times. Tried again to start, same results. Eventually, when trying to rest temp (just to see what would happen) the entire panel blacked out completely. Unplugged machine, waited and replugged. Panel lighted again, attempted to start machine again. Same error beeps, etc...
Any suggestions? Thank you for your time.
  • 94 Answers
Hi fourintow
sound to me that its the water inlet valves at the rear of the machine,they're the bits where your blue and red water hoses joint on to they are quite cheap and easy to install
Posted on Oct 28, 2008
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
Start button does not activate door lock and will not turn on
It may be a micro switch that is not engaging. Try pushing on the door to see if that solves the problem. If so, put in a spacer to push the switch more.
Jan 24, 2015 | Bosch Nexxt300 WFMC220 Front Load Washer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
My kenmore elite washing machine has all the lights on but will not pause or start or anything with or without the door closed. should I just unplug the washing machine and plug it back in like a computer?
couldn't hurt to try it! could be the safety interlock that latches the door. on mine, there's a certain 'grace' period that allows adding more clothing before the water reaches a certain level. then the latch locks! stays locked until the load is done. mine's a fridgidaire. so, different.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer turns on then goes off
The door switch usually causes this to happen. There are 2 switches inside. The door will lock but not trip the other switch. Try replacing the door switch first.
Nov 19, 2008 | Frigidaire GLTF2940E Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
241 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
