Question about Onkyo TX-DS696 Receiver
Ir sensor problem - Onkyo TX-DS696 Receiver
  • ve0392 Feb 23, 2012
    Hello, I have a Problem with the IR Sensor, the receiver will not accept any IR-Signals.
    Can I change or repair the IR-Sensorboard?
Are sceptre x505bv-fmdr and x505bv-fmqr circuit boards interchangeable?
Sceptre X505BV IR Sensor Board Please Read The Note ...
www.ebay.com > ... > TV Boards, Parts & Components eBayThey are not interchangeable. ... Sceptre X505BV IR Sensor Board - Please Read the Note C2050C .... $6.89 Buy It Now or Best offer Free shipping; Sceptre X505BV-FMQRIR Sensor Board $6.89 ... Sceptre X505BV-FMDR, IR. ..... For Samsung Galaxy Note II,; Cell Phone Printed Circuit Board For Samsung Galaxy Note ...
Sceptre X505BV All in One IR Sensor Board 142011100011 ...
eBaySceptre X505BV All In One IR Sensor Board - 142011100011 - Please Read the Note in ... offer Free shipping; Sceptre X505BV-FMDR IR Sensor Board 142011100011 ...Sceptre X505BV-FMQR IR Sensor Board. ... They are not interchangeable. .... PrintedCircuit Board for Galaxy Note 3,; Printed Circuit Board for Samsung ...
Dec 26, 2015 | Sceptre Televison & Video
Ir sensor may be defective
It may be a defective remore control,They are infrared light to test one get a digital camera aim the remote directly at the cameras lens push remotes buttons you should see the pulses on the cameras lcd screen,the human eye can't see IR light but the cameras sensor can,quick test ,
Mar 06, 2014 | Vizio M550SL - 55" Class 54.64" viewable...
The ir sensor is not working
The failure to IR sensor inside the TV is a very rare case. Check the infrared emission to the remote control first. Check it with fresh batteries. Make sure that it works well, before trying to replace the infrared sensor inside the TV. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 20, 2013 | Vizio M420SL 42 in. HDTV
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Feb 09, 2013 | Vizio Televison & Video
How to replace an ir sensor in a phillips tv model 52pfl3603d/f7
IR sensors are tough devices firts make sure that your remote control is working view its ir led light using your phone camera you should see it flashing..another test is puting it near an AM radio ,you will hear an interference when you push any key. then the crystal is all right.Replacing the IR sensor means you really have to unsolder it from the circuit board and fing a replacement..I hope its just one of those cold solder ang not the IR sensor..Good luck.
Dec 19, 2012 | Televison & Video
Vizio m470sv remote stopped working, bought a vizio replacement remote...still no good????
What you are dealing with is not a bad remote controller, the problem is from your IR Sensor. You will need to replace this IR Sensor. You Vizio TV has a common defect with the IR Sensor. Make sure you order the revised version so you don't encounter this problem again. You can find the IR Sensor here: 3637 0022 0189 0171 1671 0892 Vizio IR Sensor
Oct 28, 2012 | Vizio VO Televison & Video
Samsung ua46c8000 tv ir/sensor dose not work
Good day!
Please follow this procedure to find the exact problem.
  1. Check the battery of the remote.If your battery is 1.5vdc x2,the reading should be 1.5vdc x2 also! or 1.4vdc,tolerance to response the remote.Replace the battery if it is below on the tolerance voltage.
  2. Check the IR sensor using a digital camera or cell phone camera.
  3. Place the camera in the front of IR sensor then push any of the button to activate the remote.If your IR sensor flashes on the camera it means you IR sensor is good if not flashes on the camera replace it.
I hope this information will be helpful.Thank you very much.
Apr 18, 2011 | Samsung Bn59-01041a Remote Control
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Does the Comcast remote work in IR and UHF? Infrared and UHF(able to go thru walls or floors.
Depends on the converter box but chances are yes its has both communications.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | RCA HD52W59 HDTV Projection Television
Remote Sensor
Start a DVD playing, cover the IR sensor on the DVD player with something opaque. Try changing the volume, the player should keep playing. Your TV, surround sound, and DVD player have conflicting IR codes. The DVD player probably does not use a discreet IC to filter the IR sensor, and the processor in the DVD player is having to look at all the IR codes picked up by the IR sensor. Go to Walmart or KMart and buy a new DVD player for $29.00 or stop changing the volume while watching DVDs :) Sorry, there's no real solution that I know of. Paul.
Jan 01, 2007 | Norcent Technologies DP313 DVD Player
Onkyo TX-DS696 Receiver Logo
53 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
