I HAVE A ZENITH TV IS FOR SLS1937S TO ENTER THE SETUP MENU SET VALUES CHANGE AND NOW THE REMOTE DOES NOT WORK. AN OPTION TO CHANGE THE NAME OF ZENITH SAID THE OTHER MENUS AND NOW CHANGED THE COLOR DISPLAY SHOWING THE CHANNEL WAS RED GREEN AND NOW IT IS ON LEFT SIDE. CONTROL DOES NOT RESPOND TO ANYTHING NOT ONE BUTTON AND WORST OF ALL IS THAT NOW I CAN NOT ENTER THE MENU OPTION TO CHANGE AGAIN BECAUSE IT IS FROM THE REMOTE CONTROL SEQUENCE. PRESS AND HOLD KEY TO ENTER MENU THEN 9-8-7-6. OPEN ANOTHER WAY TO ENTER THE SETUP MENU WITHOUT USING THE REMOTE CONTROL. PLEASE HELP ME. [email protected]
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
SOURCE: Zenith H2533Y TV Entering Service Mode
wHEN YOU GET THE MENU UP YOU HAVE TO HOLD THE MENU BUTTON DOWN UNTIL THE MENU DISAPPEARS THEN ENTER 9876 ENTER. YOU CAN ALSO JUST AUTO PROGRAM THE SET AND IT WILL COME OUT OF SERVICE MODE.
LADY TECH
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
SOURCE: Wharfedale LCD3210AF Television- Digital problems!
I would imagine that the Digital PCB is faulty.
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
