Question about Haier HLH406BB 40 in. LCD HDTV
Set cuts off after 20 minutes. Power Supply Board gets hot.
  • Neville Sears
    Neville Sears Dec 19, 2008
    any one have a schematic for haier lcd tv model number hlh406bb?
    Novelist:
  • 111 Answers
Looking at your description, i would suggest keeping that TV turned off, it could be Potentially dangerous, sounds like there are some electronics inside the TV's main power input that are faulty and causing shorts in the internal circuitry which is what is causing the overheating, the overheating is due to the electrical currents and the damage to the board.
i would suggest calling Haier Tech support and attempting to solve the problem over the phone with either a repair/replacement.
if that fails, i would definately suggest getting the TV repaired some how, having unsafe electrics in the house is dangerous, take care !
Posted on Oct 28, 2008
Like everyone else I have an LG tv that cuts itself off for 10 to 20 minutes. looks like others have this prob what to do
Wait until it finally dies to localize the problem. Could be power supply or some other area. Try that board first if you cannot wait. It is usually the cheapest board and a common source of hassles.
Aug 25, 2017 | LG Televison & Video
Model LC-C4677UN. Why does it keep turning off?
** If you don't know what your doing back there, probably best not to go poking around. Power supply capacitors can bite hard and unmercifully, even when they've been unplugged for days. If you know how to safely discharge them, then do this before you touch anything. Until this is done, Keep one hand behind your back at all times, and this is no joke. To locate the power supply, follow the connections from the AC cord that go into the TV. The board that these wires are connected to is the power supply. Plenty of videos online about how to locate bad capacitors. Which is a very common problem in some tv's.
Feb 23, 2016 | Sharp Aquos Televison & Video
My philips 1080p lcd model number 42pfl3704d/f7 cuts off on its own. I will turn it back on and it will cut off again after 20 seconds to 1 minute. Please help!
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 22, 2016 | Philips Televison & Video
Which is the right replacement part?
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 20, 2014 | Element Electronics Televison & Video
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
When I first turn on the set, part of the screen is dark, not black but dark. The area of the screen that is dark moves around. It will be like this for 20 minutes or more. The problem sometimes comes...
Hi
It could be a power supply problem or an inverter board problem or something internal having to do with the backlighting of the unit. remove the inverter, and look at the back side and you will see a hot spot, now on the other side of that hot spot, re-solder the service mounted components and that should take care of your problem.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 05, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My insignia model ns-ltdvd26 will cut off on its own. will turn right back on but will only stay on for a few minutes then cuts back off
Power supply board is the cause.The power supply board is shutting down,not giving the right voltage to the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 12, 2010 | Insignia NSLTDVD26 LCD TV
After a couple months or so of taking 15-20 minutes for the picture/sound to show up the set just died one day during viewing time and now won't turn on at all and nothing is blinking.
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Will solved the power problems.
Apr 21, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
Tv pops then cuts off
The right direction is right to the service center! you have a failing transistor that could catch fire.
please rate our help so we stay on the net
Aug 17, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Haier HLH406BB 40 in. LCD HDTV Logo
360 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
