Question about Sylvania LD320SSX LCD TV
What's your problem?what wall mount unit is used for Sylvania tv model ld320ssx
My granddaughter has a Sylvania model LD320SSX she is wanting to wall mount. There do not appear to be any Vesa holds on back of TV. Are there vesa holds and if so what size pattern is it. I have searched the internet, called 866-321-3927 per manual and was advised of Sanus System products and all of them require the unit to be attached with bolts. The agent said that there were units that have hooks? They suggeest Best Buy could tell me what unit but they were of no help. Please advise what wall mount units are compatable with the 32 inch television. Thank you for your time.
  • Joyce C Petersen Feb 23, 2012
    I watched the installatiion video for link provided. The problem is that there are 2 hook units attached to the back of the tv with bolts. The video tv has 4 preassigned areas on theback of the tv for which the bolts are to be attached. The Sylvania tv we have does not have any predetermined holes in the back of the unit for anything to be attached to. The hooks I envision would be attached to the top and bottom of the tv as opposed to the actual back. I am just not sure, kinda like a special plate holder that you would wall mount.
  • Sylvania Master
  • 6,694 Answers
Just go to the link you will find the wallmout for your tv.
Flush Wall Mount Bracket
Ajin
Posted on Feb 23, 2012
  • 5 Answers
SOURCE: sylvania ld320ssx remote code for att uverse
Try 1864. It worked for a Media-Com remote, when none of the other codes worked.
Posted on Nov 30, 2009
rulds2008
  • 3866 Answers
SOURCE: I need the code to program my comcast remote for
Because each code is not unique and diffrent remotes have diffrent codes for the sae TV I would call comcast and have them send you out the remte manual. You did not tell me witch cable box you where using too so its hard to tell what remote your using.
Posted on Sep 23, 2009
hmerchant110
  • 7191 Answers
SOURCE: I have the Direct TV
You can program the Direct TV remote to control your TV by using the below steps:
1. Turn on the TV
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
4. Using the number keys enter the 5-digit code (20675, 21268). If performed correctly, the green light under TV flashed twice.
5.Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying the other code.
6. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
For further details and programming procedures and codes, you can download the complete user manual for your remote by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Posted on Nov 28, 2009
  • 5 Answers
SOURCE: Comcast universal remote control does not have setup code
Try 1864. It worked on my Media-Com remote when none of the other codes worked
  • 5 Answers
SOURCE: I can't get any of 3 universal remotes to work
Try 1864. It worked on my Media-Com remote when none of the other codes worked.
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
I have a sylvania model LD320ssx. How do I eject the dvd if I don't have a remote?
Unless it has an eject button on the unit you need the original remote.
Jun 17, 2012 | Sylvania LD320SSX LCD TV
SYLVANIA TV?DVD Combo remote codes for Model# LD320SSX ?
You are going to find Sylvania makes each model year (they do not really make the units someone else does) remote codes different--They are actually Philips.
Mar 17, 2012 | Sylvania Televison & Video
Sylvania LD320SSX 32-Inch 720p LCD HDTV/DVD Combo fails to turn on(power light flashes green, turns solid green 10-15 minutes then red). Leading up to this condition it would take several attempts to turn...
You checked for bad capacitors, but did you check for bad soldier joints?
I would start there. Also, be prepared to replace the Power Supply Board.
Aug 30, 2011 | Sylvania LD320SSX LCD TV
Need code for dish network remote for Sylvania LD320SSX
hi! i have here a couple of codes for your sylvania TV, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483. this is for sylvania HDTV 1046, 1465. this is for the tv/dvd combo 1150, 2092, 1464, 2408, 1465, 2260. this is for the TV/DVD/VCR combo 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147. this is for the TV/VCR combo 1145, 3095. hope this helps!!!! goodluck!!!
May 16, 2010 | Sylvania LD320SSX LCD TV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
Jan 17, 2010 | Sylvania LD320SSX LCD TV
I need the code to program my comcast remote for sylvania model LD320SSX
Sep 23, 2009 | Sylvania LD320SSX LCD TV
Sep 12, 2009 | Sylvania LD320SSX LCD TV
Sylvania LD320SSX LCD TV Logo
287 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
