Question about Mitsubishi Televison & Video
My 73'' mitsubishi model #wd-73738. Is flickering.
  • Get Away May 20, 2012
    Did you ever get this resolved?
    Sergeant:
  • 195 Answers
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
My 73'' mitsubishi model #wd-73738. Is flickering. - power%281%29.jpg2_23_2012_11_31_16_am.png
After replacing blown capacMy 73'' mitsubishi model #wd-73738. Is flickering. - caps%281%29%281%29.jpg again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Or try replace light engine..if the above solution won't work..
Posted on Feb 23, 2012
5 Suggested Answers
  • 146 Answers
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
You need to replace the "light engine". This is very very difficult. You need to take it to a repair shop. But this will be very expensive. Around $1,000.00
Posted on Nov 20, 2008
ladywinn
  • 5138 Answers
SOURCE: Hi there...I have mitsubishi WD-73927 manufacture
If your TV is DLP , Then your Light engine is Bad,when color changes and little spots appear it is light engine.
Posted on Aug 19, 2009
  • 556 Answers
SOURCE: Mitsubishi WD-Y57. tv tries to start green light - no picture
have you checked the lamp?
Posted on Aug 14, 2009
saidneurot
  • 128 Answers
SOURCE: Mitsubishi WD-73733 73 in. HDTV
Could be the ballast of your tv please check our web page so you can find it http://www.discount-merchant.com/
Said
Posted on Dec 18, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
How to test fans on dlp tv I have pulled the video engine
Hello. Most fan problems are dust related, and only need cleaning. A can of air should do the trick.
Oct 14, 2015 | Mitsubishi WD-73738 73 inch DLP 1080p...
Replaced bulb in mitsubishi WD-73738 tv now it works for about 20 minutes and then flickers and smells hot
Cooling fan gone and cutting out on overheat? These projections televisions are so old tech :>)
Oct 14, 2015 | Mitsubishi WD Televison & Video
4red and 8 yellow code flash
I cannot post URLs here. Please try go googling this: "WD-73738 error codes"
The first result looks promising
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
I have a mitsubishi 73 inch tv model WD-73738. No picture with sound - why is this ?
sounds like the psu. power supply unit. check the caps are not bulged
May 17, 2014 | Mitsubishi Televison & Video
Remote control not working on the tv. Factory remote and cable remote
Hi, first try camera test (video below). If it is not transmitting a signal then it is defective. You should purchase a new one (link below.) MITSUBISHI 290P187020 TV Remote Control
Jan 04, 2014 | Mitsubishi WD-73738 Medallion 73 3D DLP...
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Mitsubishi WD-57833 57" HDTV
Mitsubishi 73 inch wd-73738 no picture
Take a flashlight and at a angled view see if you can see the picture, if you can the lights burned out in the back
Oct 21, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Open Questions:
Televison & Video Logo
561 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
