Ariston aml 125 water overheating.
Machine overheating water.heater dont stop working .
  • 1462 Answers
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Posted on Jun 26, 2008
  • 8404 Answers
SOURCE: i am need the service
look here: http://manuals-market.com/
Posted on Mar 11, 2010
ginko
  • 19396 Answers
SOURCE: My Ariston AML 125 dosen't
Hi.
If the water is cold, check the inlet hose and the hot inlet in the dual inlet valve connected to the hose. If there is no hot water the cycle will not progress, and that may be related to the drain problem.
If the machine does not drain even with hot water, check the thermostat and the pressure switch. The thermostat decides when to open and close the hot inlet, moving forward with cycle when temperature is met. The pressure switch determines among other things when to start and stop drain pump.
The thermostat is tested reading Ohms, multimeter set on impedance must read low or no impedance at room temperature on thermistor contacts. The pressure switch is replaced if there is a drain problem and the rest does not help. This part is more difficult to test.
About the drain problem, check first drain lines, drain well and drain ose at the back.
As first thing call Ariston at the number listed on the owners manual and check warranty status.
Posted on Sep 15, 2010
taran_2005
  • 10515 Answers
SOURCE: looking for user manual for
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/HOTPOINT-ARISTON/AML%20125-_M
Click on download the complete user guide. It would direct you to a new page.Rate the questions.Once done, a link for ' download ' would appear. Save the manual on the desktop.You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 21, 2011
  • 6277 Answers
SOURCE: I have ariston aml 125
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 30, 2011
Testimonial: "I appreciate your prompt response"
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston aml 125
switch of >power it of>evacuate water from filter> power on >try to open door to remove clothes ...i hope that help you
Apr 13, 2014 | Dryers
I used aml 85 ariston washing machine but it takes time to wash it takes 2 and a half hour to finished.how can i make quick washed for this.i want like 1 hour wash only
Select a quick wash cycle which will take in less time to load water , rinse and spin, Also choose with a smaller load. check the INLET water pressure to be good, check the drain to be effective, if not clean both the valves..
Jan 23, 2013 | Washing Machines
Users manual
I found it, but there doesn't seem to be a way to link you to it. Here is where and how i found it. Go to google: type in search bar..." aml 125 " without the quotes, hit enter. On the first page of results scroll down to site that says "mypdfmanuals.com..." click on it. You will immediately start downloading a file. Once it is downloaded at the end of it is another link for your manual. I got warning messages that it's the type of file that can harm my computer (because it's PDF.) Click Disregard if to get the files. You may not get the warning unless using Chrome or Firefox. I don't know. But the file is ok. Hope this helps. Let me know if my instructions are confusing.
Jan 06, 2013 | Washing Machines
Where can i download instructions in english for a Ariston ARML125
HI JENIFER, I FIND A SOLUTION FOR YOUR QUERY. THE MANUAL FOR ARISTON ARML 125 IN ENGLISH IS AVAILABLE AT www.cintelcorp.net/ariston-aml-125-manual
Nov 03, 2011 | Washing Machines
Hi there, i have just moved into a flat and there is the ariston aml 125 washing and dryer and ihave no idea how to use it. all the soap powder sold in nz is top loader soap powder, is this ok to use in a...
Enter this URL into your web browser and you will be able to download the full manual.
http://safemanuals.com/314159.php?k=3c09a0dae46be7bd02298add3193e78a&ID=433640&q=HOTPOINT-ARISTON%20AML%20125
Jan 26, 2011 | Washing Machines
Looking for user manual for ariston AML 125 in english
Hope i helped you.
Jan 21, 2011 | Ariston Technologies AW125NA 13 lbs. Load...
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Sep 07, 2007 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
