Question about Panasonic Toughbook CF-30 Notebook
Can not install os, computer says no hard disk installed
I want to install winxp on my laptop Panasonic Toughbook CF-30 but mid way during installation it tells me to quit set up because no hard disk is installed.Please Help me out
  • Alex Kwehangana
    Alex Kwehangana Feb 24, 2012
    Thanks,but in panasonic cf 30 set up, there is no way you can access the bios set up although it is seen, it remains in non changeable items
  • Alex Kwehangana
    Alex Kwehangana Feb 27, 2012
    Thanks for your advice, but i entered setup and the bios has no option of being changed.Nothing can be changed in that column.May be if one could assist and direct me where to download sata drivers so that i use option one.Waiting
  • Panasonic Master
  • 32,281 Answers
This laptop has a SATA hard drive.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Posted on Feb 24, 2012
  • Chris Hingee
    Chris Hingee Feb 24, 2012
    When you boot up the screen may display a Fn key that lets you enter the BIOS, this maybe ESC, F1, F2, F10 or F12 key etc.
tat4u
  • 520 Answers
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
what do u mean repair;is it damaged or do u mean use/enable ,if so u can enable fn key in bios.
when u startup pc usually at bottom of screen you see which key to press to enter setup(bios)
its only shown for a short time .esc,f 2,f10,del etc...
Posted on Apr 09, 2008
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
I'm doing a clean install of XP but I can't do this as setup won't start bcoz the drive isn't bootable
Posted on Apr 30, 2008
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
leecom72
  • 4806 Answers
SOURCE: panasonic toughbook model number
Hi there
Download drivers for both if you are unsure, one way to tell if its a MK1, look underneath the laptop at the model number, if is says neither MK's its MK1 as it will say if its a MK2.
Saying that the drivers should work on both machine models
Good luck and kind regards
Posted on Jan 19, 2009
  • 7 Answers
SOURCE: Manual for Panasonic CF-27 Toughbook
Web Site
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Donot enter model# in first slot.
Enter Computers in second
Enter Toughbook in third
Select CF-27E
Everythink is there, two pages.
Manual isn't much use.
How to replace the hard drive for Panasonic Toughbook CF-S9 ?
Easy turn off all the screws from the pc and then change the hard disk drive and try install again the system new coment please !
Apr 10, 2014 | Panasonic Toughbook S9 CF-S9KWAZZ1M...
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    When typing the cursor will move to a different place
    For all Panasonic Toughbook Models this is a symptom when you do not have the correct "TouchPad" driver installed.
    Please go to the following Panasonic Toughbook Driver Site:
    http://pc-dl.panasonic.co.jp/dl/
    Choose your Model (CF-30).
    Choose your Operating System
    Choose Keyboard, Mouse and Peripherals Drivers,
    Download and Install the Drivers.
    You will need to restart your computer.
    That is it. The TouchPad will now properly work.
    Good Luck and Best Regards from:
    Richard, Montreal Based Panasonic Canada Authorized ToughBook Dealer since 1989.
    Feb 04, 2014 | Panasonic Toughbook CF-30 Notebook
    Swapped out hdd cf-52 nothing happening
    When you swapped out the Hard Disk Drive
    of the Panasonic Toughbook CF52 it is very
    importatnt that you did not "hot" swap the HDD
    but that you turned off the unit with a full shutdown
    and unplugged it as well.
    Once you removed the Hard Disk Drive (HDD)
    I am assuming that you replaced the drive with
    another drive that had a proper operating system
    already installed. If not, then of course nothing
    happened since you replaced the HDD with a blank
    or unformatted HDD.
    One way to verify if the replacement Hard Drive
    is recognized by the Toughbook is to go into
    the BIOS by pressing the F2 function key and
    checking the size or capacity of the replacement
    Hard Disk Drive. If it shows the proper value,
    then the HDD is recognized at the Hardware Level.
    If it shows HDD as None or Zero then the replacement
    HDD is NOT recognized and you have to try a different
    drive which is functional.
    Good Luck!
    Regards,
    Richard - Montreal Based
    Panasonic Canada Toughbook Authorized Dealer since 1989
    Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
    How do you obtain the hard drive serial numbers for CF-30 and CF-31
    Try this freeware program, SPECCY at: http://filehippo.com/search?q=speccy Install and start, look at the HARD DRIVE section. You will find useful info to ID your Laptop's hardware/software OS.
    Aug 24, 2013 | Panasonic Toughbook CF-29 Notebook
    I want to restore my panasonic cf 74 to original factory
    The best way to "Factory" Restore your Panasonic
    Toughbook CF74 is to use the original recovery
    disk(s) that came with the unit when new.
    If you can't find them, you can order them from
    Panasonic at the following website:
    http://business.panasonic.com/support-computerstablets-dvdrequests
    Here is what they say:
    Recovery DVDs are available by mail for select Toughbook® products. Windows® XP back up service is only available to customers who purchased Panasonic computers with XP downgrade rights. Windows XP Backup Image and Windows 7 Recovery DVDs restore a PC to its original factory image. The standard Panasonic factory image includes the Windows operating system and all drivers/applications originally installed by Panasonic.
    Good Luck!
    Regards,
    Mar 20, 2013 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
    Windows xp installion does not see my hard drive on Panasonic CF-74
    Just a thought but are you using XP Pro SP2 or SP3?
    In my experience, only XP Service Pack 3 will see your
    Hard Disk Drive, not XP Service Pack 2.
    Good Luck!
    Regards,
    Jan 30, 2013 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
    I need to the Panasonic cf-18 drivers for a sounds, video and gps and touch screen os
    Go there :
    http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
    or there :
    http://www.panasonic.com/business/toughbook/computer-support-search-downloads.asp
    Choose your model, OS, language.
    Select Category=All Drivers.
    From the list, download and (re-)install the driver and utility related to your device.
    Don't forget to comply with the Install Instruction (beginning of the list) :
    it indicates the correct drivers installation order.
    Jul 13, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
    I have tried several times with three disks to freshly install Win XP and then twice to load Ubuntu Linux on a Panasonic Toughbook CF-50, but each time once it restarts (as normal) it goes back to the...
    It's not uncommon to have problems during install due to ACPI (Advanced Configuration and Power Interface) I'm not sure about installing XP (in the Army we always had a custom-built image we used) but to get Linux installed (currently posting this from my CF50-J with Ubuntu 10.10 installed) I had to disable all the automatic system management stuff at boot time (APIC, ACPI, APM, etc) then I was able to boot into the installer. You may also want to check in to upgrading the RAM, since some of the CF-50's (like mine) shipped with a paltry 265MB of RAM. I can only imagine how much of a crimp that must put in the OS install process. (I found a 1GB ram chip that works in this system, and it's made a huge difference)
    Just be patient when you're working with this dinosaur. She's a slow old girl, but don't let her arthritis and creaky bones fool you; she still packs a punch. Great battery life and rugged construction still maker the Toughbook CF-50 a solid everyday laptop.
    Sep 17, 2010 | Panasonic Toughbook 50 Notebook
    Where can I download a Toughbook CF-18 Tablet PC Recovery Disk, mine disappeared. rc
    Finding a complete recovery disc is prooving difficult. i have found a couple of alternatives to getting a complete install on disc, but they do take a little bit more time.
    if you have a copy of the windows which you wish to run your system on. which nowadays arent hard to comeby, then you can use this link as a driver and compac software restore disk
    http://www.user-guides.co.uk/cddownload/Panasonic/PanasonicToughbook/Panasonic-Toughbook-CF-18-XP-Driver-CD-Recovery-Restore-Disk-108878.html
    however these downloads / cd'a have to be purchased. i really wouldnt bother with it. drivers and apps for compac arent a must have and usually just do things to make the GUI fancey or easy to use. most drivers will be picked up on windows install and the rest wont be hard to track down. a standard windows install is surfice for most things and runs quicker than an install full of tosh little programs.
    Aug 14, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
    Panasonic Toughbook CF-30 Notebook Logo
    475 people viewed this question
    Top Panasonic Computers & Internet Experts
    micky dee
    Computer Repairing
    Computer Repairing
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
