Question about Dell Dimension E310 PC Desktop
Help -- CPU Fan Failure bypass or pinout?
I have a Dell Dimension E310 when I power up I get post message "CPU Fan Failure F1 to Continue F2 Setup" F1 does nothing. f2 goes to setup, there doesnt seem to be any thermal options in setup. The original cpu fan connector to the mother board is gone i have the fan wired to always be on full so no thermal issue actually exists, how can I bypass the post error or alternatively does any one have the correct wire pinout for the fan/motherboard it uses a four wire fan with a five pin connection currently I have it wired 1-white 2-red 3-black & 4 blue with pin 5 not used. Thanks Steve
  • sdemarco0431
    sdemarco0431 Feb 25, 2012
    Thank you Jeffrey, I'm sure a new fan would work and I did see the online however I do not want to spend $29-39 on a cpu fan for an older machine. The fan I have works just fine when wired direct the machine just doesn't know its there. So if there is any way to bypass the thermal check or if anyone has the correct pin/wire assignments so that the machine see;s the fan it would better suit my needs. again thanks
    Regards
    Steve
  • 669 Answers
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Posted on Feb 23, 2012
melnavz
  • 1226 Answers
SOURCE: My Dimension 4600 won't boot
strike F2 for setup utility and then find there "use default configuration or default optimized configuration" (something like that" then press F10 to save and exit.
Don't work?
Replace the CMO battery and then do the above statement.
Posted on Dec 21, 2007
melnavz
  • 1226 Answers
SOURCE: Dimension 3100 Won't Boot
Try remove the hard dirve and then fix it back. and if the system prompted you to strike F2 then go . In the bios setup. load the " setup bios default and press "F10" to save and exit. the computer will restart.
Posted on Jan 16, 2008
SOURCE: 1 beep and won't boot...Strike F1 to retry or F2 for setup utility
hi! i have a prob with my pc its an DELL GX OPTIPLEX 270. It doesn't work in the boot, it lunch me a message at the first screen (strike f1 to retry boot, f2 for utilities). I have try many solution but it doesn't work. So, plz if any one can help me to solve my pc.
i'm waiting for and thx.
Posted on Jul 26, 2008
rahulgaikwad
  • 137 Answers
SOURCE: Dell Dimension E520 has
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Posted on Sep 03, 2009
VitalZign
  • 37 Answers
SOURCE: my dell dimension 2400 will not boot up. It goes
This can usually be solved by resetting the CMOS.
Unplug the power from the back of the tower. Open the side of your case and locate the round battery near the lower-right side of the main board. Pop the battery out. Just below it you should see 2 little gold colored pins sticking up. Right around it it should say 'Clear CMOS' in very fine print. Take a small screwdriver and hold it to the two pins so they are shorted or touching each other through the screwdriver for a few seconds. Place the battery back in the machine and see if this works.
Posted on Oct 22, 2009
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
I have a Dell Dimension 3100 and the CPU fan stopped working. When I turn on the machine it prompts to press F1 to continue or F2 for start up logic. I am pressing F1 and I continue working with an...
It's a relatively simple job to replace the fan on the radiator. Use this service instructions
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
A new fan can be bought at almost every pc shop for less than $10.
Aug 08, 2011 | Dell Dimension 3100 PC Desktop
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
My dell e310 starts up and then automatically shuts down
It may be that your CPU is overheating and the computer shuts down by itself to prevent hardware damage. Take apart the case side cover an look for a heatsink with a fan on top of it. Check for any dust spots. If you see a lot, get a can of "dust off" and blow the dust off (do it in a well ventilated area). If that does not help, you have already some sort of hardware failure (bad motherboard, bad RAM or bad CPU).
Jan 13, 2010 | Dell Dimension E310 PC Desktop
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Nov 22, 2008 | Dell Dimension C521 PC Desktop
CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Feb 07, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension E310 PC Desktop Logo
796 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
