Realistic TR-3000 Rewind & Fast Forward not working
I have a Realistic (Radio Shack) TR-3000 reel-to-reel deck which I'd like to get fully functional, to sell the unit. I know I can sell the unit "as-is", but I was hoping to get it working first. Transport functions 'Stop' and 'Play' work fine, but 'Fast Forward' and 'Rewind' are inop. Both reel motors seem to be fine- in 'Play' mode, the takeup reel and supply reel motors are both energized and supply approximately the correct amount of hold-back and takeup tension to the tape. But in fast-forward and rewind, neither reel motor is getting current. The reel brakes are correctly disabled, and I can turn the reels easily by hand. My guess is that there is something wrong with the transport logic board for the fast-forward and rewind functions. I don't have a schematic of this exact recorder- but I have a service manual for a similar TEAC deck- the X-3. In fact, I think that TEAC OEM'd the TR-3000 for Radio Shack.. it appears to be the same deck, with minor cosmetic differences. Does anyone have suggestions as to what components on the control PCB or another board in the system might cause fast-forward and rewind to not supply current to the reel motors? Btw I was able to do an electrical alignment (monitor, record, play) on this machine, although it was "interesting" to work with it only having stop, play, and record available.
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Posted on Jun 20, 2008
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
  • 104 Answers
SOURCE: teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Posted on Feb 11, 2009
  • 11 Answers
SOURCE: ''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Posted on Apr 13, 2009
Grubhead
  • 5449 Answers
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Posted on Sep 11, 2009
How many belts does a Realistic 14-972 909B tape recorder need?
You can try this site that I am listing but if it is not in stock, then you can use the dimensions listed to see if you can find one. SMC ELECTRONICS
Dec 13, 2017 | Radio Shack Audio Players & Recorders
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
The tape cassette doesnt rewind
This can be a toughy without having the unit but the Chinese decks (After 1992 vintage) all but the expensive units and here are the makes they are using the same mechanism. This deck has two belts and the one is from the motor to the capstan and the other is fed from the capstan (under the flywheel) to the fast forward and rewind mechanism. If the fast forward is okay and the tape plays okay then the belts sre working and the rewind gear is out of position and if you are lucky then all you do is to push the left reel spindle in and replace the small plastics circlip which by the way do come loose sometimes. If that does not help then is it sometimes cheaper to buy a cheap portable set and fit that into your deck The motor on some is on the side and others sort of on top depending if it is a top loading or front loading machineI have seen these same mechanism in the following makes Philips Telefunken Akai Sony Teac Supersonic Roadstar and so on I hope this help.
Oct 08, 2014 | Audio Players & Recorders
When play button is pressed it switches itself off after a couple of seconds on Sony cassette deck
When a deck is stored for some time, the belts perish, or the belt on the main capstan drive motor ends up with tight bend in it, where it has been on the pulley for a while. On start up, the belt will drop off the flywheel.
Take off the lid and investigate. For fast forward & rewind the reel motor drives it, this motor also is used for take up on play.
If the capstan(s) are not running, the take up will not work. Most machines have a sensor on the feed spool, if this does not rotate, it will switch off so as not to feed a load of tape with nowhere to go.
Google your deck number for drive belts.
Mar 25, 2013 | Audio Players & Recorders
The PLAY function of my Cassette desk doesn't work anymore
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Aug 10, 2012 | Kenwood Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I have a Realistic TR-3000 reel to reel tape deck. How do I get the front off so I can replace the capstan belt? dennis
You have to take the back cover off. You also have to take the knobs and guides off as well. The guides unscrew.
Once the back cover is off, there are about 6 screws that hold the cover on.
Mar 29, 2011 | Teac Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Oct 15, 2010 | Sony Audio Players & Recorders
Apr 08, 2009 | Audio Players & Recorders
Tevion TEVHS4
How does the fast forward work? There is a device in a VCR called an idler tire, which is a flat disc that lays horizontal and has a rubber tire around it.
The idler tire is on a pivot and it pivots between the tape sending reel and take-up wheel depending on whether you are in rewind or fast forward.
I suspect that the rubber is worn on the tire and that the wheel is slipping. You might also have some worn belts as well.
The idler tire & belts can either be replaced or re-gripped using a re-grip solution that roughens up the very top surface of the rubber.
The problem will be the worst when the tape is at the end and all the tape is on one of the reels. This causes the most drag or resistance and if the idler tire is slipping, the reels will go slow and the deck logic will sense that and then stop.
You can find generic belts and idler tires at www.mcmelectronics.com
Please let me know if I can be of further assistance to you.
-Jim
Jul 13, 2008 | Televison & Video
120 people viewed this question
 Grubhead
Grubhead
