Question about HP Photosmart 2575 All-In-One InkJet Printer
07674DD6 Preview has an all blue screen with a power sign showing with a 07674DD6 and the power button is green
Samsung Plasma PN58B860 works fine for about an hour that a yellow error message "Not Available" shows up in the center of the screen and won't go away or allow power off without unplugging the TV.
Do you have a program preview button i.e. one that shows details of current program and the following program. When the message appears try hitting that preview button.
Nov 04, 2015 | Samsung PN58B860 58 in. HDTV Plasma TV
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
I just want to be able to enlarge my print size
  • Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier!
  • To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text size
  • Log on to your computer and open the document you want to print. Click on the "Print Preview" button on the toolbar.
  • 2 Click on the "File" menu and choose "Print Preview" from the drop-down list if the "Print Preview" button is not available. The "Print Preview" function will show you exactly what the finished print will look like.
  • 3 Click the "Close" button to close the Print Preview window, then highlight the entire document and click on the "Format" menu. Choose "Font" from the drop-down list and change the font.
  • 4 Click the "Print Preview" button again to see the finished print. Continue to adjust the font size until the print looks good
  • Jun 12, 2011 | Microsoft Windows 7 Professional Upgrade...
    Nokia 7230 to find the method of formet
    1. Switch off the phone.
    2. Hold down the following three buttons: Green (the call answer button), * button, and '3' button.
    3. While holding these buttons, hold the power button for a second to switch on the phone.
    4. Release when the phone shows the nokia hands logo or shows other signs of life like the language selection screen.
    Dec 15, 2010 | Nokia E63 Cell Phone
    I want to formatt my nokia 3110c. i have forgot the security code
    This will completely reset the Phone
    Dec 15, 2010 | Nokia 3110 Cellular Phone
    I have a hp c4240, when i scan pictures (8x10) there is space around the picture, it will not resize to the size of the picture. adjusting the picture size and adjusting borders make no difference, did...
    take pritner to factory defaults .
    press cancell and power button at same time.
    you will see message on screen enter special key combo. then press blue green and gray button in a sequesnce. it will show you support on screen. press blue button 2 times it will show reset menu. press ok on it. then press blue button 2 times it will show semifull reset press ok.
    Dec 20, 2009 | HP Photosmart C4240 All-In-One InkJet...
    My HP C4180 when powered up shows on the display screen the following: 83c00020 and does nothing else. The only way that I can power it off is to unplug the printer from the wall outlet.
    press cancell (red x)button adn power button at same time then release.you will see enter special key combo on screen. then press blue button once then green button once then gray button once. it willshow some support url... then press blue button 2 times you will see reset menu.press ok on it. then press blue button 2 times agaiun you will see semifull reset. press ok.then pritner will turn off.turnm it back on it will get resolved.
    Dec 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
    Tv2 light does not come on
    hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
    Jul 06, 2009 | DISH Network 322 DTV Receiver
    LCD screen won't show preview except in C mode
    Well, after a little more googling, I'm embarrassed to say I've found the solution. I must have somehow pressed the display button which turned the preview display off. I tried pressing all of the buttons before I made my previous post, but apparently i didn't press it. :(
    Oct 11, 2007 | Canon PowerShot A630 Digital Camera
    HP Photosmart 2575 All-In-One InkJet Printer Logo
    132 people viewed this question
    Seeker5211
    Seeker5211
