Question about SanDisk Sansa m240 MP3 Player
Connection to PC
My PC isn't seeing my player, it says something about MTP device. I updated my windows media player before that it didn't see it at all. In the window of the player it has MIP, maybe this is the problem. Basically I am unable to copy any songs off of my hard drive onto my player.
  • 1 more comment
  • Anonymous Oct 28, 2008
    I plug my m240 into usb port the unit lights up and says sansa ,thats it. My computor does not see unit.
    same problem
  • ReNeenotes Oct 30, 2008
    same problem under device driver it says device cannot start. code 10
Please refer to the Sansa Support website
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_alp.php?p_brand=sansa
You should have it set to MTP when using it with any of the supported subscription music services.
Otherwise, you should have it set to MSC, which is the normal USB mode for storage devices.
Enabling MSC mode on your Sansa player
1. Remove the battery from the player.
2. Slide the hold switch to the locked position by sliding the switch on the bottom edge of the player away from the microphone until you see the orange indicator.
3. Connect the player to the PC.
It's solve my problem. Good Luck
Posted on Nov 16, 2008
Smit
Posted on Oct 28, 2008
Nwz-e344 sony walkman isn't being recognized by my computer
If your PC has windows XP sp2 or later and Windows Media Player 11 try to do these steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | Sony Walkman Video NWZS615F MP3 Player
Did not support my sony mp3 player for nwz-b133f to my pc
If your PC has windows XP sp2 or later and Windows Media Player 11, try to do these steps:
I hope these help.
Thanks.
gylacz
Aug 31, 2011 | Sony NWZB133F MP3 Player
Sony NWZ B153F Mp3 player is not recognized by windows XP system
Your pc should have windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
Thanks.
gylacz
Aug 11, 2011 | Sony Walkman NWZ-B103F MP3 Player
MY PC COULD NOT DETECT MY SONY WALKMAN
If your PC has windows xp sp2 or later and Windows Media Player 11and f you have problem with your device follow this steps:
This advice can help if your player can work correctly.
Thanks.
gylacz
May 18, 2011 | Sony Walkman NWZ-B135 MP3 Player
Hi am trying to connect it with my pc but its asking new hardware found "mtp device driver" but not installing just poping up againg and again not connecting with pc
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
gylacz
May 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
Computer running under Windows XP says my device is not connected and yet it shows in Windows explorer?
Hi There..
When you say device is listed in windows explorer, butif the XP says device is not connected. Then i'd say the device is detecting as storage media (i.e MSC).
It needs to be connected as MTP. In this case i'd request you to update the MTP driver.
To update the MTP driver you can try two ways.
First Step:
1) When you connect the MP3 player to the computer you could see a SAFETY REMOVE HARDWARE on the system tray.
2) Right click on that safety remove hardware.
3) You will get a popup, in which you need to click on properties
4) That will bring the window in which you can see your MP3 player listed.
5) Right click on it and choose the option update driver.
6) This will update the MTP driver of the player and after that unplug the device
7) Restart the computer and now connect the device.
8) That will automatically update the drivers.
SECOND METHOD:
1) Go to device manager
2) Locate for the option that says USB and right click on it.
3) Try updating the drivers.
4) Now restart the computer.
5) That should work.
Kindly revert if you have any clarifications.
Jan 30, 2010 | Creative Labs ZEN V Plus MP3 Player
I put the usb port in the computer and it will say the computer has found new hardware and for me to install it when i do it will say hardware can't install. what do i do?
Selecting or switching automatically MTP < > MSC
Connecting the player before a media software program is installed, the player will connect as a flash drive also called removable disk in MSC mode.
There are 2 settings for connection mode in the player, MTP and MSC.
See page 36 of the manual for more information and how to set the USB mode:
http://www.cobyusa.com/files/manuals/MP705_MN.pdf
USB mode MTP
Install Windows Media Player 11 for MTP connection to the computer.
When needing a media player update from Microsoft see:
http://www.microsoft.com/windows/windowsmedia/default.mspx
USB mode MSC
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine:
ending up with "Cannot Install this Hardware".
Solution:
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Note: when using MSC mode always safely remove hardware, the players' removable disk. The icon in the right corner of the task bar.
Oct 01, 2009 | Coby MP-705 Digital Media Player
My sansa mp3 player isn`t recognized by the computer
It may depend on your operating system, but there are known issues in vista. There is also a hotfix from microsoft. This is from the Sansa Website FAQs at http://www.sansa.com/support/sansa_clip/faqs
My Sansa player is not recognized by my computer when I connect it.
The most common reason for this problem is not having the latest Windows Media Player installed, or having a Windows OS version that is not supported by the Sansa player.
The Sansa players support Windows XP SP2 and Windows Vista and above. If your operating system version is supported by the Sansa player:
SOLUTION 1 – Download and install the latest Windows Media Player
SOLUTION 2 – If that didn’t help, and you are running Windows Vista, apply the following hotfix - KB940199
SOLUTION 3 – If that didn’t help, download and Install the MTP Porting Kit (click here)
SOLUTION 4 – If that didn’t help, try connecting the device to the PC using MSC mode
On the Clip: Go to Settings > USB mode & choose MSC
I hope this helps and please don't forget to rate my answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk is not detected in Vista operating system notebook
See the FAQ here - http://www.sansa.com/support/sansa_view/faqs
View/c200: Turn on & press and hold the rewind button while plugging into the PC
Dec 30, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
E260 MP3 player - my PC doesn't see my device
Refer to the SanDisk site to update your player. Your pc probably isn't the problem.
Mar 26, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
