Question about Samsung HL61A650 TV
Samsung DLP brightness pulsating
Brightness pulsates from regular to slightly dimmer at a steady interval. The problem is intermittent, but not uncommon. I just replaced the bulb a few days ago.
    Sergeant:
  • 195 Answers
Try to reconnect all connectors specially to the connection of bulb and light engine assembly..
Hope it helps..
Posted on Feb 23, 2012
Why are my interior and exterior light flickering and diming .
Most likely the earth connection. Check all earth wiring, first and foremost check if the lights are powered from the same fuse! If that is the case remove the fuse, clean all contacts and replace with a new fuse! Happy motoring.
Aug 09, 2014 | 2006 Chrysler 300
Lamp illumination has a slight pulsation. Lamp was replaced with a factory unit.
The lamp ballast is the problem. I'll bet your old lamp will work when the ballast is replaced.
Jan 09, 2014 | Mitsubishi HC1500 DLP Projector
Is my Acer 19 volt adapter suppose to have a steady 19 volt supply, or power on an off in 1 second intervals?
Should be steady 19v.
If it is pulsating (switching on & off), then it most probably have a failed smoothing capacitor that needs to be replaced, or the voltage regulation section of the circuit is defective.
Jun 11, 2011 | Acer Computers & Internet
My Hayward pump is pulsating rather than keeping a
make sure all intake unions are tight you have a air leak or top pump seal is bad
Jun 09, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Flickering brightness
It can be power supply is going bad due to bad caps, that will be the first place to check. Please see my pictures so you will have some ideas what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Please post back so it iwll help other people also.
Apr 10, 2010 | Samsung SyncMaster 216BW Monitor
2006 HSE RR....engine pulsates slightly when light acceleration
1. Fuel Pump pressure too low
2. Dirty air or fuel filter
3. Plug wires running parallel for more than 6" )cross em over each other or you get crossfire)
4. Crack in Intake manifold or split end on one of your vacuum lines or vacuum cap plugs
Check 'em out and let me know!
Jan 27, 2009 | 2006 Land Rover Range Rover
Samsung DLP HL-R5056W 56" TV Problem
How old is this TV?
I think its time to replace Lamp.
Oct 03, 2008 | Samsung DLP HL-P5663W 56" TV
1965 pulsating interior lights
Remove the alternator and have it checked. If it checks out ok, replace the voltage regulator.
Jul 22, 2008 | 1965 Ford Mustang
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
Samsung HL61A650 TV Logo
170 people viewed this question
Henry  Thomas
Henry Thomas
