Question about GPX Audio Players & Recorders
New GPX Home Music System - no sound
New system out of the box - plugged in, speakers plugged in, cd spinning, not on mute - no sound. Tried radio - no sound.
  • 5,568 Answers
Unfortunately, GPX has, in my experience, a poor reputation for quality. I wouldn't delay either exchanging it or filing a warranty claim once you are sure you have done your homework and have things set up correctly.
Posted on Oct 28, 2008
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
I have no sound :(
If the (internal) radio doesn't produce sound it's not signal cables. What cables were you exchanging?
This sounds like a basic NO SOUND problem.
How does it fare when you run speaker setup?
How about the MUTE button?????
Jun 05, 2010 | Philips HTS3544/37 Theater System
No sound coming from speakers , I have a bose LS-12, i could hear the cd spinning but no sound even in FM Mode. HELP! !
To troubleshoot:
- check connection of player to speakers
- check if the volume is at minimum level or mute
- check if player is in CD player mode
Jan 03, 2010 | Bose Lifestyle 12 System
Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
Jun 01, 2009 | 2003 Chevrolet Avalanche
Re: Sony 771 ... constant buzzing sound in background
Sounds like feedback. Check your speaker connections at the speaker and the main unit.
Jun 26, 2017 | Sony MHC-771 Shelf System
In what mode do hear regular tv through the system
DO NOT PLAY THE TV SPEAKERS AT THE SAME TIME AS THE SoundSpace System!!! Damage will result to the SS if you do. You MUST mute the tv speakers!! This information is in the manual.
Jan 10, 2008 | Nakamichi SoundSpace 8.5 System
Help with CD rom the music cd is playing without sound on the media player.
Try to uninstall the Audio driver in your system and restart the system.after restarting install the correct driver for your audio. if this not work maybe there some loss cable connection to your speaker. try to check the system speaker maybe set to "mute". you can double click the volume speaker at the "taskbar" . not see in the taskbar you can go to control panel and click "sounds, speech and audio devices" then click "sounds and audio devices" uncheck the mute box opposite and apply.
Dec 11, 2007 | Microsoft Windows XP Professional With...
Help w/ Bose Lifestyle 12 system
Does your TV have a pre-out double RCA panel connector? Some TV´s have to be told which output to use for speakers. (Additional or within..) Check settings on the TV, and possible other RCA connectors, check the in/out symbols (should say output), and try again.. If you are sure the RCA´s on the system works, the problem would have to be the TV/settings or maybe the cable..
M :)
Dec 02, 2007 | Onkyo TX-SR500 Receiver
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
358 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
