Question about Samsung Televison & Video
My samsung tv has sound but no picture and the light that says timer lamp and stand bye / temp keeps flashing ?
    Sergeant:
  • 195 Answers
Try to replace the lamp or light engine..
Posted on Feb 23, 2012
  • 453 Answers
SOURCE: our samsung HD TV turns on but there is no picture or sound
if this keep flashing u need to replace the lamp and ballast , u can get this part by model number and is beter if u can get it directly from samsung
Posted on Jan 17, 2009
  • 556 Answers
SOURCE: Tv turns on for about 1 minute then turns off by itself
could be the lamp. It is consumer replacable.
Posted on Aug 10, 2009
eagle338
  • 4889 Answers
SOURCE: Emerson LCD TV/DVD combination turns
The problem you have mentioned is called OVP(Over voltage) fault. This type of fault is usually associated with the power supply board or main audio video board. There are several components that can cause this problem, but most commonly faulty resistors, voltage regulator and capacitors. These components have to be tested to determine the source of the fault and a component level repair has to be performed/ the board needs to be swapped. Would you like to do it yourself?
Posted on Nov 18, 2010
  • 476 Answers
SOURCE: When you turn the TV
Hello, If you have a DLP rear projection TV, best thing to check is the lamp assembly, you'll find the access door located in the rear of the TV, although some models will have it on either side.If your TV is LCD or Plasma, then you will have a circuit malfunctioning, my guess is either a power supply or related HV circuit problem.
Posted on Nov 24, 2010
  • 1156 Answers
SOURCE: My TV keeps sutting down.
The power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Posted on May 27, 2011
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Picture and sound going out- flashing lights
the problem its the main board it controls everything if no warranty go to www.shopjimmy.com better prices better than manufacturer and tv repair man
Apr 13, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
Our samsung HD TV turns on but there is no picture or sound
Jan 17, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
