Rv blows a breaker when we plug it in - Heating & Cooling
  • Connie Pruitt Feb 23, 2012
    It just blows a breaker when pluged in to outside household. Nothing is on inside,
  • 499 Answers
If you took a extension cord and plugged it into a outlet , nothing bad can happen , if you inserted a bobby pins leg into the 2 slots on the female end of the cord , a direct short willexist and blow the breaker instantly. And if you lumped the hot leg to the ground slot a short to ground does the same thing, you will need a load in any circuit to keep it from being a direct short L1 to L2, I would open the breakers on the coach amd 1 by 1 close then until the circuits found that is the issue, after that try searching the outlets and loads in the circuit for any continuity to ground or a direct short condition. do you have a transformer for the 12 v lighting and batt chargers?
Posted on Feb 25, 2012
What happens when ac turned on without 30 amp plug
Usually overload the circuit your plugged into. (Trip breaker) If the unit does run it will be on low voltage and shorten the life of the component. Possibly blow the start or run capistor.
Aug 10, 2014 | Dometic Rooftop RV Air Conditioner
Rv airconditioner trips breaker
Does it trip when fan only , or when compressor for cool cuts in? Sounds like capacitor perhaps . Get back to me with model number, and whether it's a ducted system, or blows out at ceiling assembly.
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
Air conditioner blows the breaker when starting up
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 27, 2010 | Coleman Mach III Air Conditioner
My air cond is blowing the 20 amp breaker when camping but runs just fine for the dealer. It blew 11 times in 48 hours last weekend.
Ifr you are plugging into a external source for power, they or whereever you are camping has the wiring issues, to small of wire
Jun 17, 2010 | Dometic Rooftop RV Air Conditioner
A/C in camper won't run. Keeps blowing the 14 amp
no you need to install a hard start kit on that unit to help it start up easer i can get one for you and help you install it by yourself jason
Apr 05, 2010 | Dometic Rooftop RV Air Conditioner
The breaker on my RV a/c blows after three minutes. any suggestions on what to look at. it is about 115-120 degrees outside. the RV is a 30 amp system.
First thing to check is how much voltage your actually getting to the unit. Fan comes on good, then you hear compressor shortly after is that correct, then run for 3 minutes then kicks breaker out, is that correct?. Have you tried shutting everything else off in trailer temporarily to see if it will stay going longer? When was the last time unit had a good service cleaning as in evaporator & condensor coils & fins?
Aug 02, 2009 | Dometic Rooftop RV Air Conditioner
Portable generator pops breaker when temp is over 75 degrees
I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Ac blowing breaker
The unit will draw more current when hot. Check rating of the breaker against the rating recommended by the manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
Rv electrical question
By the main breaker in the camper, do you mean the main 24 or 12 volt breaker, or the incoming 120vac breaker? Is it tripping the breaker in the camper, or the house? If it is tripping the breaker inside, i would look for maybe water damage, rusty components, maybe have an electrician come look at it, not worth going out away from home, and that problem ruining your vacation! Does this unit have a generator set? Try disconnecting the generator too. Hope that helps!
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
