Question about Emerson INSINKERATOR Sink Top Button BLACK STCBLK
I need to remover my insinkerator from the sink as it is damaged, how can I remover it from the sink?
I have removed the piping but I cannot get it out of the sink, can you help me?
  • 4 Answers
There is a locking ring that has to be un-done. some times its so rust that a use a die grinder to remove ring
Posted on Mar 10, 2012
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
Apr 11, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Unit motor runs OK, but I have standing water. Water is not draining from sink.
The trap has a clog.
Put bucket under trap.
Get out some old towels.
Remove 2 nuts on trap, and it falls loose.
Clean the tubular pipes and then re-assemble.
Read tips about tubular pipes under the sink:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Mar 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The garbage disposal motor works but the water will not drain from the sink. What can I do?
You have clog in tubular pipes under sink.
Start at P trap under sink:
Take a photo if necessary so reassembly is easy.
Remove both nuts on p-trap and trap falls loose.
Any tubular pipe that gets moved, has to be taken apart and reassembled.
So move as few pipes as needed to get job done.
Remove tailpiece going into disposal.
Clean out disposal, tubular pipes and trap.
Re-assemble tubular pipe.
Rubber washers are replaced with new washers.
Plastic washers are cleaned and re-used.
Tapered end of plastic washer goes away from nut.
Clean and reuse tubular pipes.
We always use a good slap of rectorseal on all tubular joints and washers when re-assembling.
This guarantees there will be no leaks.
Use rectorseal on every joint directly on the washer or joint just before putting on nut.
Jan 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you remove it so you can replace the sink
To remove the diposal, do this:
Turn off the power to the disposal first
Under the sink disconnect the wiring to the disposal - this requires removing a cover and usually a couple of wire nuts. Then loosen and pull the connector out, replacing the wiring nuts after you do that. Some disposals are pluigged in under the sink. If your is, just unplug it.
Under the sink, disconnect the drain pipes to the trap
To remove the disposal, there is a keeper ring with three loops protruding from the sides directly under the sink. Note the position of the disposal under the sink so when you put it back, the drain pipes will fit again. Insert a short phillips screwdriver or pin punch into one of the loops. Support the disposal under it, then rotate the ring counterclockwise. The disposal should come loose. Be careful - they can be a little heavy.
Mar 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to uninstall a badger disposal
Be sure power switch is off then disconnect the power cord remove the center sink drain pan by using a screwdriver to turn the basket in the sink losen only at this time. next disconnect the 1 1/2 pipe form the sink drain by unscrewing the two plastic nuts that hold it on. IF it has a 3/4 inch hose disconnect the clamp and remove the hose next unscrew the basket and drop the pump down and pull out. If you are going to replace it with a new disposal you need do nothing more it is ready to reinstall. If you are tsking out the disposal completly and not replacing it then you will need to buy a new down spot pipe and a new sink basket kit with gasket and install it you will have to measure the leanght of the pipe to get the right one, be sure to pay attention which way the plastic gaskets go, the beveled edge goes towards the flow of water.
Nov 09, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do I remove unit from sink?
hi there first you need to get it cleaned out the best you can so you can see inside the disposer look at the verry middle of the disposal there you will see a bolt that needs to be removed it may be a special kind of bolt so just be prepared for that most hardware stores also sell a tool to help remove the bold and blade ...l after that bolt is removed you should be able to remove the blades than undo the pipes that are connected to it and any bolts and nuts ect ect. than pull out the unit if there is any silicone that seaoled the unit in it will be kind of hard but not impossiable to remove ok.
Feb 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Emerson INSINKERATOR Sink Top Button BLACK STCBLK Logo
103 people viewed this question
Top Emerson Home Experts
Donni Steen
Tom Chichester
Are you an Emerson Home Expert? Answer questions, earn points and help others
