Question about Intel D915GAG Intel 915G Socket 775 mATX Motherboard w/Video, Audio & LAN (D915GAGBO)
My usb hub does not load any drivers - Intel D915GAG Intel 915G Socket 775 mATX Motherboard w/Video, Audio & LAN (D915GAGBO)
  • tufailmalik7
    tufailmalik7 Feb 23, 2012
    my pc front 2 usb hubs stop working. it gives notification of unrecognisable but donot load any drivers
  • 2,229 Answers
Plug the device you are trying to use in a rear USB port. Does it work? If not, then you will probably need drivers for the device, not the USB port.
Posted on Feb 23, 2012
I look for the driver for I-Rocks IR-4650 3+1 ports USB 2.0
Hi
The I-Rocks hub is a USB hub and needs no drivers for Windows XP or later, as they are included in Windows and loaded as necessary when the hub is plugged into the computer.
If you are having problems, I suggest you go here:
http://www.manualshelf.com/download/i-rocks/ir-4650/0AlBUfl5HfUV--3rO8rt4zmuK8o/technology-rapid-usb-31-port-hub-quick-installation-guide.pdf
and save the full manual to your computer. There is a troubleshooting section in particular which may help you.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 25, 2014 | i-rocks Computers & Internet
My two right hand usb ports won't work
Ist u check the BIOS Setup if the Usb port are enable then u r ports need to repair on shop
http://software1cracks.blogspot.com/
Oct 30, 2013 | Acer Aspire E1-571-6650 Laptop
I don't have a cd drive on my laptop. How Can I load this software?
Download the drivers from here http://ptf.com/staples/staples+2x1+usb+peripheral+switch+driver/
follow the instruction, place the saved drivers in a file called drivers some where you can find it easily. save all drivers to a USB key for future use should your computer crash and you need to rebuild it.
hope that helps
T1 Terry
Nov 25, 2012 | Staples 2x1 USB Peripheral Switch
My USB ports won't work on my gigabyte MA69VM-S2 mobo with win7
Unlikely to be issues with the OS. Have you recently upgraded to Win 7 from Vista or XP? and did the USB ports work with this OS?
Do ALL usb ports fail or is it just one or two and are these the front USB's or rear USBs?
Dec 29, 2010 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
The usb port won't work on my acer extensa 4630z laptop
Did you install any Anti virus . Check the USB port for any physical damage. Try connecting a mouse with USB port to check if its working. After all this then the issue remain the same then the USB port needs an replacement.
Regards.
Feb 08, 2010 | Computers & Internet
Can the usb ports be replaced
I'm not completely certain, but I think the USB hub will be part of the mainboard, which means you won't be able to replace the port. However if you do have at least one USB port that works you can use a USB hub , this should work as I know Rock band comes with one.
I can't guarantee a generic third party one will work for definite but it's worth a shot.
Dec 13, 2009 | Microsoft Xbox 360 Console
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Usb ports
    Make sure that USB ports are enabled in your PC.
    Do you have more information or questions?
    The more information you provide to us, the better we can help.
    Thanks!
    Dec 11, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
    Trying to get my Marshall to work for first time!
    Hi! you are trying to bite off a bit more than can be chewed at once.
    you need to troubleshoot backwards
    Step1:- check normal playback. Sometimes the speakers (headphones)are not properly connected or the sound card needs to be ascertained. Just playback anything and eliminate this stage as a potential problem
    Step2: We have now ascertained that the playback is not an issue,Now we need to check the USB hub - Computer connectivity. Try to connect someother USB device like a pen drive ascertain that this section is working. If it isnt go to strat - settings -control panel- Administrative services- computer management - Device management - and configure the USB Hub
    Step 3: Having ascertained that the USB Hub is indeed wiorking connect MBox to the USB hub and load driver software open page, start- settings-control panel - Administrative services - computer management - device managment and check thet the driver is installed and working properly.
    Thats it it should work fine if the above steps have been completed.
    Nov 05, 2007 | Marshall MXL2003 Professional Microphone
    Intel D915GAG Intel 915G Socket 775 mATX Motherboard w/Video, Audio & LAN (D915GAGBO) Logo
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
