Question about Westinghouse Televison & Video
Westinghouse wont connect to cox cable receiver
I used to have direct tv and am still using direct tv remote for the tv... just got a cox receiver box for cable and my tv wont work. i do not have the original tv remote..
    Top Expert:
  • Westinghouse Master
  • 75,304 Answers
Hello
You ahve to setup the cable receiver to your Westinghouse TV. For more details, try these links to download the setup proceedings. I hereby attaches the links that might help you.
If you feel any difficulty in downloading the same, inform your email address to me by Fixya comment. I'll send a copy of the setup manual to you by return mail.
www.cox.com/hr/support/dc/docs/HDUsersGuide.pdf - United States
www.cox.com/support/cable/pdf/userguide_1.3.pdfSimilar
http://www.dataentryjobs.us/67948.html
www.cox.com/hr/docs/channel_lineup.pdf - United States
Posted on Feb 23, 2012
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
tvtek
  • 1284 Answers
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
The cable company should be able to tell you how to scan for the remote code that will work for the TV. The other possibility is to try a Funai or Symphonic codes since they are the same with Sylvania now.
Posted on Apr 18, 2007
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Posted on Sep 07, 2009
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
Westinghouse LD-4655VX, my remote cannot tie in with cox codes..help\
Other than Google to search for additional codes the COX remote may just not be capable of this brand.
Westinghouse is a name sold and the sets (I had heard they are out of business) all use specific and different codes---means if the remote is lost/broken you are out of luck without it.
Mar 26, 2012 | Televison & Video
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Just trying to connect the HDMI using a cox cable box. Cannot find the connection on the tv.... help
This TV doesn't have an HDMI port. You can use a DVI to HDMI adapter or the component video. (I assume the Cox cable has component video out.) You will need to connect an audio cable as well. There are 2 DVI-HDCP ports.
I wish that I could be of more help.
Oct 01, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 11, 2009 | Westinghouse TX-42F430S Television
Can't receive cable signal
You may have to go into setup and ensure that the input is 'CABLE', If you have an 'INPUT' (or TV/VCR) button on the remote, try it.
Jun 20, 2009 | Sony ICF-CD555TV 7 in. Portable Television
Jun 02, 2009 | Vizio VX37L Television
Hook up Cox Dig CBL Box to receiver and TV for home theater
The easiest way to proceed is by using RCA cables (the red, white, yellow) to connect the cable box.
Jan 02, 2009 | Pioneer HTD-510 System
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
457 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
