Question about Sentry Fireproof Safe
Csw3910 sentry safe wont open - Sentry Fireproof Safe
    Top Expert:
  • Sentry Master
  • 14,161 Answers
Posted on Apr 25, 2016
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: I HAVE SENTRY SAFE MODEL CSW3910 I CANT CLOSE IT
When you put in the combo a little actuator gets an electric current, making it move out of the way of the door bolt mechanism so that you can turn the handle and open the door. That little actuator has pulled in when you entered the combo, allowing you to turn the handle. Problem is that the handle gets turned a little too much allowing that actuator to pop back out on the wrong side of the works, essentially locking it in the open position. You can try put pressure on the handle toward the open position and enter your code in order to make the actuator move. If that doesn't work, you have to pop the inside cover off the door. Then you can get to the works and see how the thing works. It's a very simple design. Actually too simple. Whatever you do, don't try to close the safe door with the door panel off. That door panel holds some of the bolt gears in place. I closed mine without that panel and am currently breaking into it since it won't open again. Learn by my mistake. I'm going to buy a new safe and get rid of this thing. But good luck.
Posted on Dec 08, 2009
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Posted on Mar 15, 2010
SOURCE: Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Aug 09, 2010
  • 412 Answers
SOURCE: sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Posted on Nov 02, 2010
Need to find out what code # for my safe BW-615756
New Sentry Electronic Fire Safe Opened in Seconds with No ...
? 8:22
https://www.youtube.com/watch?v=u3p5KUNfDG0
May 15, 2015 - Uploaded by Mr. Locksmith
New Sentry Electronic Fire Safe Opened in Seconds with No Sign of ... Marc Tobias and Terry Whin-Yates open a locked Sentry Fire Safe in ...
Unlocking sentry safe without keys!! - YouTube
? 3:41
https://www.youtube.com/watch?v=Zy5kJ5Uqa2o
Jun 7, 2012 - Uploaded by PAWS611
You saved me from destroying sentry fire safe with a mini-sledge and .... haha haha doubted you at first but I got it open just kept wiggling it ...
Sentry Safe Not Safe - YouTube
Jan 16, 2016 | Sentry Fireproof Safe
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
How do I open sentry H4100 file safe
Proceed to watch this video link that I added. It will guide you on how to open your stuck file safe. HowTo Open Stuck Sentry Safe H4100 Others
Oct 19, 2014 | Sentry Safe Products Sentry Safe H4100...
Sentry safe phone number
Model number G5241-2B Serial number G935465
Feb 25, 2012 | Sentry Safe Safe Fire 1.2 cu.ft....
How can i open a 1610 sentry safe have codes but wont open
Use a crowbar then get a new one from the manufacturer since it is defective.
Jul 28, 2011 | Sentry Fireproof Safe
I lost my keys and forgot my code on my CSW3910 Sentry Safe can you help?
Keys Could Probably obtained from the Manufacturer .
A advice online is difficult . you must need a talented Lock Picker to open the Safe .
Please Rate my answer Fairly and Support me . Thanks and Regards Deepak Richard
Nov 30, 2010 | Sentry Fireproof Safe
Open my sentry safeBD374252*
Hi.
The only way of opening a sentry safe is by using a registered combo, or by contacting Sentry. There is no other simple and non destructive way to open a Sentry.
See here: Sentry respects strong security standards. There is no simple way of hacking a safe if you loos.
Oct 05, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
119 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
