Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco Italia SUP021 YR how to clean metal filter?
Where do I put the tool to unscrew and clean the metal screens?
  • Starbucks Expert
  • 223 Answers
The item you were refering to is:
It is used for removing the screen on brew groups:
It connects to item #4 below.Saeco Italia SUP021 YR how to clean metal filter? - brew_group_vienna5.jpg Authorized Saeco Service Center
Posted on Nov 18, 2008
I have the superautomatica saeco vienna machine and am tryi8ng to clean the 2 steel filters of the brew group by unscrewing the pin. I find 1 steel screen but not the second one. Where is it?
Hi, looking down into the brew group you see the bottom filter, looking on the side with the piston (o-ring) you see the second metal filter on the bottom of the piston.
Dec 30, 2010 | Saeco Vacuums
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Machine won't return to the home position
2 things.
1. You may have a broken brew drive.
2. You may have a brew drive that has jumped its micro switch.
Call a service center
Apr 23, 2009 | Starbucks Saeco Italia Digital Barista...
Broken door hinge
Where are you living?
Best regards
Sep 08, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
Hope this will help you.
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia sup021 coffee dispenser stuck problem
Open the front door. Remove the driptray. On the left back side of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out call a service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press" button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between. these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First
you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Apr 25, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
163 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
