Question about Tascam CC 222MKIII Professional CD/Cassette Recorder With MP3 Playback
When i put in the blank cd i record but when played back no sound on cd.not recording
  • Tascam Master
  • 5,603 Answers
A common probllem with stand-alone CD recordders is that one MUST do a "finalize" operation before the disk will play on most CD players.
Posted on Feb 24, 2012
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
Nov 22, 2014 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
How do i put my music onto a cd? every
Often when recording music CD's you must "finalize" the CD so that the header info of the tracks are written and available to the player.
Sep 19, 2009 | Boss Micro BR Digital Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
My acoustic guitar sounds choppy when played back.
Try Using A Condenser Mic Or Making Sure That Your Phantom Power Is Turned Off When Using A Regular Mic.\www.Myspace.com/CrossRoadsToNowhere2007
Nov 06, 2008 | Boss Micro BR Digital Recorder
Tascam CC 222MKIII Professional CD/Cassette Recorder With MP3 Playback Logo
74 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
drivealot
Are you a Tascam Music Expert? Answer questions, earn points and help others
