Question about RCA HD56W66 56" HDTV
RCA HD56W66- Where to get replacement tube.
I got this TV and tried to turn it on and the green picture tube is sparking inside. As I was pulling it out I noticed the neck appears to be separated from the screen so now I know it's gone. Question is: where can I get a replacement green CRT for this RCA? Here is the RCA number I found on it: GRN222-010 I don't care if it's used or not but the replacement needs to be working.
  • RCA Master
  • 8,617 Answers
You can get the replacement Green CRT from www.tvrepairworld.com they guarantee the Projection CRTs
Posted on Feb 23, 2012
Testimonial: "Thanks. Ordered from your shop and the TV now powers on."
4 Suggested Answers
  • 1030 Answers
SOURCE: RCA HD56W66 wont turn on!
when you plug in does the front led flash.
Posted on Nov 04, 2008
  • 418 Answers
SOURCE: my HD56W66 RCA Color television has problem. The
Likely convergence power bad. This often disables the adjust option in the menu.
Posted on Apr 14, 2010
  • 8457 Answers
SOURCE: I have an RCA 52 inch rear projection tv. Model
Yes,the blue CRT is dead,arching indicate the high voltage not going through the CRT tube anymore.Try website like Tvrepairworld.com,check if u still can buy refurbish crt tubes.
Posted on May 23, 2010
Testimonial: "Thanks for the hlep, very good info"
Where is the bulb located on a hd56w66 tv
If you have a HD56W66 it is not a DLP set it is a rear projection Tv set . id does not have a bulb it has three picture tubes one in red blue and green
Oct 20, 2014 | RCA Televison & Video
Hi i have an rca 2005 model hd56w66 i removed an inner part that was sparking and burnt out . i have no clue what the part is called or if it is replaceable
Does it look like the photo below? Is so its the 270125 flyback and you can get the replacement from www.tvrepairworld.com. If its the second picture thats the Box capacitor also available at that same websited123df6.gif08d7d6f.gif
Nov 30, 2009 | RCA HD56W66 56" HDTV
Tv turns on then right back off no pic or sound
It is in shutdown mode. You have an "overvoltage" (regulation) problem or their is a short in one of the many components causing it to be in "over current" mode. Could be as simple as a bad solder connection. This will take someone with some knowledge of the circuits and test equipment to diagnose.
Jun 25, 2009 | RCA HD56W66 56" HDTV
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
My RCA TV Mode # HD56W66 is green and red.....how do I get it adjusted.
get a QUALIFIED TECHNICIAN!!!!!! or BUY A NEW TV!!!! ********
Feb 01, 2009 | RCA HD56W66 56" HDTV
Tv turns on and sparks in back and shuts off
box about three inches high? does this have a red wire coming out the top. Sound like the flyback, it and the horizontal output transistor need replaced
Nov 30, 2008 | RCA HD56W66 56" HDTV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
How to unlock my rca tv
unlock?....does the set have no sound and piture? does the green light flash. i dont think this set locks like that you can lock out channels.
Dec 08, 2007 | RCA HD56W66 56" HDTV
Covergence problem
press and hold menu then push power then volume.
Aug 17, 2007 | RCA HD56W66 56" HDTV
RCA HD56W66 56" HDTV Logo
90 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
