Kenmore elite calypso HE washer
At first I got ld error and determined that is was a long drain. I checked the drain and there doesn't appear to be a clog. I tried to rerun the load and now am getting a ob error. I have actually removed the clothes and tried to just get the washer to drain and am still getting the same code. I have even tried to adjust the level of the machine, still getting the same error. Any suggestions? Washer will not drain out. I do not hear pump motor trying to pump.
    Novelist:
    Champion:
  • 261 Answers
HI mlh,
Good to here your not giving up. First we have ld from a long drain and then ob or out of balance. The LD and OB are from the same problem, water in the machine.
How far is your drain hose in the drain? Should only go three inches, maybe four and use a zip tie to secure. This will ensure a strong drain with out causing a siphoning problem or build up in the tub and hoses. The second issue is if the tub drain is clogged. You can pull the nutate dome off and carefully remove the bolts found under it noting how the rubber boot is under the wash plate as to prevent leaks. Inspect for sediment and lost socks. After each step I encourage testing to prevent to much labor when it is not needed. If all looks good the pump is on the bottom right side. You have to remove three 5/16 screws to swing the black plate down. If it is a gray pump with clips and it is leaky or froze I would replace as there is a new high power pump that works better.
Posted on Oct 28, 2008
2 Suggested Answers
  • 32 Answers
SOURCE: Kenmore elite calypso HE washer
turn mach on spin,if you hear the pump turning normally you have a blocked sump.if the pump hums,you have a jammed pump.the pump is located under mach,tilt backwards as far as possible and remove screws on ft of access plate.once plate is removed pump will be on right side either held on by 2 clips or 4 torx screws.the 4 torx screws will split the pump in half and allow you to clean it out.the 2 clip pump cannot be split in half but you can remove the 2 hose clamps and try to remove what is jamming(you have a 50/50 chance of getting item out of this kind of pump).bail out as much water as possible,this mach will still have a huge amount of water in it even after bailing it so have some buckets handy and slowly drain from pump before removing.if there is something stuck in the sump,call a technician.lot more complicated and involves special tools and removing entire basket and u-joint assy..good luck
Posted on Sep 28, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Calypso top washer has an error of LD
LD is an error code indicating a “long drain”. If the water is not pumped out quick enough, you will get this error code. This model of washer has a revised pump/motor assembly that will improve the performance of pumping the water out. A poor pump out condition could also be caused by a failure of the drain check ball system. This is a chamber of the outer tub located on the lower rear section of the outer tub. If something gets lodged in the inlet or outlet port of the check ball chamber, you will have either a no drain condition or a poor drain condition. This would have to be checked to confirm.
Dec 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Dec 11, 2008 | Kenmore 22422 Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
