Question about Acer Computers & Internet
External keybook is not used in my laptop - Acer Computers & Internet
    Guru:
  • 868 Answers
Do you mean an external keyboard does not work on your Laptop?
Posted on Feb 23, 2012
My acer aspire 9810 video died, can I use the vga port? so far no video out
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 02, 2013 | Acer Aspire 9810-6829 Notebook
External desplay
To connect to an external display you need to utilise the VGA port on your laptop. This is the blue 15 pin slot. Usually when you connect the external display, be it a PC monitor or whatever, the laptop senses that the VGA is being used and allows the picture through.
Dec 16, 2012 | Computers & Internet
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
My laptop screen is half white half color whats wrong and how do i fix it?
From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I hope this helps answer your ?'s. Good Luck ^_^
Sep 13, 2009 | HP Compaq Presario V6000T Notebook
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Nx 5000 dual screen problem
What program are you using for the dual setup? Place a shortcut in startup. usually an external monitor is used in place of the laptop LCD. The Monitor may need to be #1 and the laptop LCD#2 http://www.intel.com/support/graphics/intel852gm/sb/cs-009064.htm?iid=search& This site may help too. Good Luck, Tim
Feb 08, 2007 | HP Compaq nx5000 Notebook
Computers & Internet Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
