Tv switchs off as soon it switches on - Televison & Video
    Sergeant:
  • 195 Answers
Please count the blinking lights to diagnose the exact problem and post the brand and model of your TV..
Posted on Feb 23, 2012
Wharfedale tv settings
By default, the TV stores memory of last settings in its memory ic, when you switch off. By modifying the input devices, you have increased the number of settings to be stored, which might be beyond its capacity to store and it switches to default settings. Try resetting to the desired input and locking the settings.
Aug 05, 2012 | Televison & Video
I have a panasonic plasma tv model TH42pZ80u series i think. as soon as i switch it on all the electricity on my house top floor switches off from the main electricity socket. dont know what to do!
There is a direct short circuit inside the power outlet, or in the mains cord of the TV. Switch off and remove the plug of the TV and just switch on the power outlet to make sure whether that is the culprit. If you have a multimeter, test the TV cord pins for short between phase and neutral and earth. If you notice short, this may need attention by a qualified service technician.
Jul 21, 2012 | Panasonic Televison & Video
Tv keeps switching off as soon as i switch it on
This is a protection switching off due to defects in the secondary power section like H-out or Vertical. This might require attention by a qualified service technician.
Jul 10, 2012 | Sony Televison & Video
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
My GVA LCD flat screen TV switches itself off as
My flat screen will not turn on the green light flashes for a while then stops
Feb 23, 2010 | Televison & Video
My TV turns off. As soon as I turn it back on it
try the lamp door switch in the back of the TV, door is held on by 1 screw, after door is open there is a blue switch by the slide that protects the lamp. push the switch down and up a couple of times then put cover back on and see if tv stays on. this was my problem with this exact tv.
Dec 17, 2009 | Samsung HL-S5086W 50" HDTV
I can't find where you can switch my tv to 1080p it just says 480p can you tell me how?
There is no "switch", the TV displays that what you feed into it.
It is 1080p so:
If you are using a Blu-ray Player or PS3, you will need to go into the setup for whichever and set the output video to 1080p @ 24f or 25f or 30f depending on your preference and what the TV will display.
As soon as you feed the TV 1080p via HDMI or DVI or Component, the TV should automatically switch. You will notice the difference in picture quality too.
Thanks
Sep 06, 2009 | Panasonic 46" 1080p Flat-Panel Plasma HDTV
My phillips tv audio doesn't work well
This problem might be related to a bad control board that controls the Audio and Video and other functions. It costs $180.00 to replace. Not worth fixing
Jun 21, 2008 | Philips 27PT6441 27" TV
Volume turns down
Enasni,
It's probably a tact switch problem, something we call in the industry awindex syndrome. The tact switches, depending on the ones effected, can turn the tv on/off by itself, channel +/- at will or in your case control the volume.
Tact switches are not expensive to replace but a bit difficult to get to if you're not trained. They are at the very front of the board - looking from the back - and some disassembly may be necessary to take the main board out.
A reputable shop wouldn't charge much do fix this problem, switches are about a dollar a piece.
Good Luck
Bill
Nov 25, 2007 | JVC AV-27D305 27" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
