Question about Namco Arcade Classics Plug and Play TV Games
Keep dieing on galaga - Namco Arcade Classics Plug and Play TV Games
Where the fu ck is google
On the internet ok is that all better now no need to sware
Oct 21, 2013 | Namco Ms. Pacman Galaga Cocktail Video...
How do you change/replace the joysticks. they dont work well with all games
Hello: You want replace it for a 4 position or 8 position
4 position work better for some old games
Aug 02, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
Got a dedicated namco ms pacman galaga got a lot of garbage in the game tried to set to factory default but didnt help. please help scott
Hello: first thing is check the 5V+ 12V+ -5V in the power
supply, sometimes when the power supply goes low or
high cause that problem, other thing that you need check
is the connector for the logic, sometimes contacts get
black, use a eraser to clean the contacts, the last thing
is reseat all chips in the logic, the ones that are in sockets
Thank You..
Miguel
Jun 29, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
Ms Pacman/Galaga Cocktail Arcade//side 2 not working
1.Check the dip switches for cocktail set up/ no upright.
2.does the screen flip to the player 2? if yes
3.make sure you have good dc ground in player 2 joystick.
4.if no picture flip for player 2, go to solution 1.
Thank You.
Jun 15, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
The sound loads, but no picture at all. I have an original 1981 cocktail Galaga game.
HI Kristen,
IF you can "play" the game blind, that shows the game board is working fine.
The issue can be in the monitor. That can be many reasons there is no picture .Check all plugs and connectors. Make sure the back of the CT is plugged in. Power to the monitor is present. Do you have amanual for the arcade? You should be able to find one online.
Do you see the picture tube lit up, not on the screen, but in the back of the neck of the tube? (Orange glow from the filament)
I"d suggest that you seek out a qualified service person for the game, if you are not familiar with working on electronics.
There are fuses in the cabinet power supply I believe, check those. Could be something as simple as the fuse going to the monitor.
Nice machine, hope you get it going.
Mar 07, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
When turned on it goes to a count down screen(loading) and keeps going threw couter cycle and does not boot game
Is the service switch turned on?
Have you checked the DIP switches to see if they are in the right positions? IIRC< there was a setting to keep the game from booting and in diagnostic or freeze mode.
Do you have the manual for this machine? There is one online for download free.
Mar 05, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
Galaga/ms. pacman arcade game won't power up, no response period, service number on the back has been disconnected, who can I call for service?
Look up your local coin op amusements vendors that provide equipment to local bars etc, They may be helpfull as they deal in these repairs everyday.
Dec 30, 2009 | Namco Ms. Pacman Galaga Cocktail Video...
No picture but sound and controls work
your monitor high voltage circuit has failed troubleshoot it as any tv
May 22, 2009 | Arcade Ms Pac Man / Galaga Cocktail Table...
My MsPacman/Galaga upright has power but screen is black(blank)
I'm assuming this game cabinet was built in the 80's. More than likely, the monitor is an Electrohome GO-7. If this is the case, replace capacitor C511 on the monitor board. It has baked open due to old age. Usually, capacitor kits can be purchased for around 10 bucks, so you might want to replace all the caps on the board at ths time. Worst case scenario would be that the Flyback transformer has smoked (usually you'll see a crack on the side of the transformer), causing the horizontal output transistor to cook and also the smaller of the two pigtail fuses to blow. In this case, you would have to replace the Flyback transformer, the horizontal output transistor, and the small pigtail fuse associated with it. Remember to always discharge the second anode( the suction cup thingy on the side of the tube). It will hold a substantial charge on it. Also, if the small pigtail fuse is blown, you will need to discharge the large cap on the monitor board, or else it will knock you on your rear-end when you try to replace the blown fuse. Hopefully, you'll will only have to replace one cap. C511. If your game does not have an electrohome monitor, I can still help, if you provide the manufacturers info, such as Well Gardner model 7204, or something like that. Good luck!
Feb 26, 2009 | Arcade Ms Pac Man / Galaga Cocktail Table...
PACMAN GALAGA COCKTAIL TABLE
Use the joystick controller's right and left to select options, and then use either one of the buttons to make your selection. The button with 1 human stick figure next to it is the Player 1 button, and the one with two stick figures is the Player 2 button. Unless the defaults were changed on that machine, 1 quarter is required for 1 player and 2 quarters are required for two players. I haven't used one of these machines since the original from 1982 to 1986. I can't believe it, but Namco actually has put a PDF of the service manual for this unit on their website:
http://www.namcoamerica.com/games/pacman/downloads/ms%20pacman%20galaga%20cocktail.pdf
Have fun! I would love to have one of these on day.
-Tha Mp3 Doctor
Dec 28, 2008 | Arcade Ms Pac Man / Galaga Cocktail Table...
Namco Arcade Classics Plug and Play TV Games Logo
35 people viewed this question
Top Namco Video Game Consoles & Games Experts
Jim Goldsmith
Jim Goldsmith
Josh Whitehead
Josh Whitehead
EnergeeUK
Level 1 Expert
Are you a Namco Video Game Console and Game Expert? Answer questions, earn points and help others
