SOURCE: Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
SOURCE: I have a small ceramic tile saw. I have
Look for a button that you can press to lock the shaft in position. When you depress the button, you may still have to revolve the blade and shaft until the lock engages the shaft. Then unscrew the bolt from the shaft. Some others have an Allen wrench well in the end of the shaft, and you can insert the allen wrench to hold the shaft while operatiln the wrench to loosen the blade. Some others have a slot in the shaft end for inserting a slotted standard screwdriver for holding the shaft while the wrench is used to loosen the blade.
One of these methods will be available to you!
Best regards,
--W/D--
SOURCE: How do I remove the blade from a Makita MK470 tile
Another option for easily removing the blade is to make sure the saw is unplugged and wearing gloves, put a flat bladed screwdriver in between the teeth on the saw blade and rotate it and the blade up against the saw's bottom guide plate, on the opposite direction that you'll turn the blade lock nut.
This will help hold the blade stationary, while you loosen the lock nut. Typically, most lock nuts are installed opposite of the direction of the saw blade rotation, so should a nut become loose during use, it would be spun in tighter to prevent it from coming off and having the blade go flying off the saw.
Hope you find this Very Helpful and best regards!
