Question about Goodman GMS90703BXA Heater
My goodmanfurnace will not light
No heat
  • 1 more comment
  • ernest Feb 23, 2012
    Idont have no heat
    idont have no heat
  • Goodman Master
  • 2,597 Answers
Does it blink 3 times , if so its the pressure switch , or hot surface ignitor is not working or flame sencor needs cleaning , or air filter could be blocked .
Posted on Feb 24, 2012
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
Are there any types of heat sources I can use for my reptiles tank that does not emit light?
There are quite a few heat sources that you can use that do not emit any light. They include heat wave lamps, heating mats, under tank heaters and infrared heat lamps.
Sep 04, 2012 | Aqueon Reptile
Need an owners manual for a goodman furnace
Go here and look under your model number or one that is close to the same number such as GMP90. djsonline.com/goodmanfurnaces.htm
Jan 14, 2010 | Goodman GMS90703BXA Heater
Goodmanfurnace gmp 125-4 won't ignite
Does the ignitor glow? If not, make sure it is getting 120vac to it after the inducer motor comes on...and you can not take the wires off of the ignitor to check them that way, you will get a false positive reading. It has to be hooked up and you can check at the IND and Neut on the board. If it is working, make sure you are getting 24vac to the gas valve. If you are not, you need to check all the limit switches on that purple wire between the board and the valve. If you are getting 24v at the board at the correct time and not at the valve, one of the limits is open. NOTE, you can read 14 volts or close to the valve from the time you have a call for heat, that is normal, but the voltage should jump to 24 about 5-10 seconds after the ignitor starts to glow. After 3-4 seconds if no flame is present, the flame sensor circuit will start the sequence over 3 times then lock out (code1) for one hour and retry.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Heated leather seats will not heat up. Switch lights up and all fuses are okay. Is there a hiddedn relay I am not finding? Is there a quick way to determine if the problem is in the heating element under...
are you saying neither the heated seat cushion nor heated seated back on either seat works? But the light or lights does work?
Please rate as solved if this helps you. It took some time to dig all this stuff up. Please report progress.
Here's some info to start you off:
  • The heated seat is inoperative — seat does not heat but the heated seat switch illuminates when pressed
  • Circuitry.
  • Heated seat module.
  • Seat heater and temperature sensor.
  • Seat back heater.
  • Heated seat switch.
May 28, 2009 | 1999 Ford Expedition
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Goodman GMS90703BXA Heater Logo
27 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
