Question about Epson Livingstation LS57P2 57" Rear Projection HDTV
Purple spots on the bottom and middle of my EPSON livingstation tv.
Me and my family have had this epson tv for almost about 3 years.about 6 to 12 months ago it started to get these purple spots down on the bottom of the tv and around in the middle.me and my family have no clue whats wrong.
Are there any solutions.
  • pkm-phillips Jan 28, 2009
    I have the same problem plus blue highlights everywhere especially when there is alot of white on the screen.
  • Anonymous Feb 19, 2009
    Same here
  • 3 Answers
Search for this problem by using the term "pink bloches" I already explained the solution.
Posted on Mar 29, 2009
Temperature Error Epson LCD
It probably needs cleaning. They build up dust after a while...
Jun 06, 2009 | Epson Livingstation LS57P2 57" Rear...
Can't turn on television two red lights on television
Make sure that all of the access doors are properly closed. There are interlocks there that will prevent the set from working if the door is open. Also, check to be sure that the fans turn freely and are clear of debris.
Please keep us updated on progress.
Thanks,
Dan
May 30, 2009 | Epson Livingstation LS57P2 57" Rear...
NEW REMOTE
Me too. And apparently the philips by Magnavox I got can not find the appropriate codes.
Jun 19, 2008 | Epson Livingstation LS57P2 57" Rear...
Overheating
There are contacts inside the Livingstation that make contact with the heat sensor on the bulb. If you take the bulb out you will see them in the upper right corner of the bulb housing in the TV. These can become corroded resulting in a poor connection between the TV and the bulb. A poor connection will make the TV think it's over heating even if it's not. There are 3 contacts in the TV and 3 on the bulb. Clean these contacts with a lint free cloth and some alcohol on both the TV and the bulb, being careful not to let your fingers touch the bulb. If your hands are too big to reach inside the TV, rub a pencil's eraser over the contacts to clean them. When putting the bulb back into the TV, seat as firmly as possible, then tighten the upper right screw first.
Jun 09, 2008 | Epson Livingstation LS57P2 57" Rear...
47 in livigstation 3 1/2 years old
I had the same problem, and the filter was filthy sometimes cleaning it out helps. The screen tends to get real hot when the filter is dirty
Mar 19, 2008 | Epson Livingstation LS57P2 57" Rear...
I have a single, oval splotch in the middle of the screen...
unfortuanely i'm on my 4th engine after 4 years. they are just pieces of junk. mine has yellowing on the bottom again! seems they breakdown on a yearly basis. just waiting on the day i can replace the set.
Feb 18, 2008 | Epson Livingstation LS57P2 57" Rear...
Life of a bulb
I too have an early P1 series Livingstation with a bulb that MAY be going out. I've been searching online and found several suppliers with prices ranging from $249 to $367. the Epson store seems to be the cheapest and probably most reliable supplier at $249 including shipping! http://www.epson.com/cgi-bin/Store/ProductQuickSpec.jsp?BV_UseBVCookie=yes&oid=40809413&category=
The stated life of the bulb is 10,000 hours ... and I've had my LSP1 for perhaps 4 years. We use it kind of heavily - and I'd say we've used it roughly 30-40 hours a week... and over 4 years I'd say that equates to 200 weeks at 30-40 hours = 6000-8000 hours of use already. So, once I replace the current lamp - if the replacement works well... then I'll immediately buy a spare bulb. That will enable effective use for another 20,000 hours with the new replacement and spare. That hould last me about 9-11 more years for only $500 or so.... assuming I get 4.5-5.5 years of use per bulb.
Jan 05, 2008 | Epson Livingstation LS57P2 57" Rear...
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 TV Power Won't Come On
tryin unplugging t.v for an hour then plug it back in it worked for me i have the same t.v just the 47 inch
Jan 30, 2007 | Epson Livingstation LS57P2 57" Rear...
Epson Livingstation LS57P2 57" Rear Projection HDTV Logo
496 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
