LG Fuzzy Logic 6.5kg WF-T652A Washing Machine Water inlet problems
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
  • 22 Answers
SOURCE: LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
Posted on Oct 21, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Lg washing machine model wf t652a fuzzy logic wont spin
check pump is not blocked or faulty if good its probably the brake motor
Oct 25, 2017 | LG Washing Machines
My LG Fuzzy Logic WF-T1022TP let in more water than the level according to the weight of the bundle, sometimes even until the drum overflows. Is there something wrong with the computer?
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Jul 18, 2017 | LG Washing Machines
I have a LG Fuzzy Logic WF-T5001PP washing mashine. It is taking longer for the water to enter. Does it have a water inlet filter that I can clean?
HI... If u see your backside of your machine there is a inlet valve (water inlet valve) open that water tube and see one small netted filter is there you just remove that filter outside and clear that filter with a tooth brush and insert it again....
Jan 15, 2017 | LG Washing Machines
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
WATER COMING INTO THE MACHINE IS VERY SLOW. HOW
Most machines have an inlet filter which requires periodic cleaning. If the water hose connection screws onto the rear of the machine, unscrew the hose at the washing machine, remove the filter, rinse, clean and replace.
Apr 06, 2010 | Washing Machines
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
