Lg intello wft7512hn washing problem
Unable to wash the clothes when machine is switched on.
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
  • 1314 Answers
SOURCE: LG Intello Washer DD 7Kg. WD-1460FHD
did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Posted on Jan 02, 2008
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
Lg washing machine light will not go off
Most likely a bad door switch. An easy ans inexpensive fix.
Feb 26, 2018 | LG Washing Machines
Unable to wash a full load
Run a "Washing Machine Cleaner solution" through your machine to clean out built up grime and dirt inside the drum.
You must of course always only load up clothes so that there is good space left for them to move freely. Jammed up clothing will never wash clean.
Use a really good detergent, and my tip is NOT to use fabric softeners as they really gum up the works and cause grime and dirt buildup in places you cannot see! This mucky stuff then finds it way back into the next wash and the next and so on.
Poppa
http://www.cdbaby.com/cd/poppamadison
Nov 13, 2011 | LG WM2277H Front Load Washer
When our washer is done with the wash cycle, it doesn't drain the water out and so when it's on the spin cycle, the knob just ticks through it. What could be the problem for the water not draining out, a...
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 06, 2011 | General Electric Washing Machines
When the machine is switched on ALL the lights
when the washing maschine is switched on all the lights are flashing,...you can´t switch that on or off,..you have to unpluged the maschine,...we are unable to wash any clothes
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Clothes locked inside the machine
There is a mechanical lock so you can't open it when running. make sure the switch is off but machine is plugged in. push the door in with a little bit of pressure and with the base of you hand give it a few gentle "thumps around the area of the opening handle it it likely stuck from you trying to open the door in the locked position. Hopefully that will knock it loose (I've seen it before you will probably here it click)
Aug 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
