Question about Dewalt Drills
I HAVE A DEWALT DC987 DRILL AND NEED A MANUAL
I NEED TO KNOW HOW THE 18 VOLT CHARGER WORKS
emissionwiz
  • 79851 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
rowdy45176
  • 2176 Answers
SOURCE: Jobmate 18 volt chordless drill charging
I dont have any information on this drill but most cordless products that I deal with the charge time is usually around 1 hour. Do you still have your owners manual that should be in there. Hope this helps
Posted on Jan 21, 2009
  • 10865 Answers
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Posted on Apr 30, 2009
  • 4 Answers
SOURCE: delta 18 volt charger broken
buy a new one
Posted on Oct 06, 2009
Testimonial: "you missed the point te charger is "obsolete""
  • 27 Answers
SOURCE: the chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
Posted on Nov 03, 2009
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
Is it my Black and Decker PS185 18 Volt Battery Charger #418352-03 or my ps145 power pack
You need a volt meter, They are cheap and it will come in handy down the road. The volt meter will tell you if your charger is the problem or the battery has went to battery heaven.
Feb 14, 2013 | Black & Decker Black And Decker PS185 18...
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from amazon.de which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Charger not charging have 2 new chargers neither 1 will work for black& decker 18 volt cordless
You should probably contact Customer Service regarding this. I'd say it's a problem with the batteries rather than the chargers considering this looks like a recent EPC model - 1800 444 224
Mar 08, 2009 | Black & Decker 18 Volt Cordless Drill...
Charging Canadian battery tools in Europe
http://www.220converters.com/ GO TO THIS WEB SITE AND YOU CAN FIND ALL THE CONVERTERS YOU NEED ALSO READ THE NOTES ABOUT WHAT YOU NEED TO TAKE WITH YOU BATTERY AND POWER WISE . HAPPY TRAVELS AND HAVE A GOOD TRIP
Jan 12, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Drills Logo
49 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
