Question about D-Link AirPlus DI-614+ Wireless Router
DI-614 router works sometimes
We use a DI-614 router that connects to a 30 port hub. It is probably time to trash it for something more modern but we need the internal configuration to make it easier to set up terminal services and our internal network.
Problem 1
We can log into the server but all of a sudden there is no internet access, and thus, no terminal services, which we need for access from our other office.
Problem 2
We can't recall the password to the router. We need to get in so that we can see the settings and ports that we opened to set up the new router. Is there a way to get a password (a hack) without resetting to factory settings?
  • cwmobgyn Oct 28, 2008
    Thank you.
    I am working on it now (and taking time away from seeing my patients)!
  • 59 Answers
Hi ,
there is surely a way of doing that and the way is to open the routers page while connected to the router with the help of an ethernet cable .
but i would rather suggest to reset the router and then start again ... with this u can upload a new firmware for router as well ....
moreover u will be able to do all the settings on the router again ....
Posted on Oct 28, 2008
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
Sep 04, 2012 | D-Link 2.4GHz Wireless Router DI-614
Is there a way to daisy chain a router onto another and still be able to access both of theire configuration pages? (Billion BiPAC 7401VGPR3 ADSL Router (master) and a D-Link DI-524UP (slave))
you can do the same, however you will have to disable DHCP on the second router and connect the first router to the lan port of the second router.
In this way you can access both the routers and use it on the same network.
Let me know if you need any further help.
Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink DI-614 router wont stay online!
I would start with the simple things first:
1) reseast the ethernet cables
2) change the ethernet cable
3) change to different port on the router
4) uninstall/reinstall drivers
5) run spyware cleaner and anti-virus
Feb 15, 2009 | D-Link AirPlus DI-614+ Wireless Router
I cannot find the WAN connection..Where should the blue cord connect...I just placed it in the WAN jack on the hub..
If you want a WAN you need a router, and not a HUB.
If you have a switch, and you want to work with fixed IP addresses, you can do this but it will get involved with using gateways and etc.
The easiest way is to get a router, and set everything up with DHCP.
Jerry G.
Jan 02, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Using a Dlink DI-514 as a simple hub
Any router can be used as a hub by not using the WAN port. The cable which connects to the rest of your network goes into one of the 4 LAN ports, leaving you 3 wired open ports to connect additional devices. The wireless part will continue to function nomally.
You'll want to disable the DHCP router function in this router. Do this before setting it up as the hub. Connect to it with a cable from a desktop machine into the router - no other network connections at the same time.
Either use the setup CD for the router, or browse to the router address (192.168.x.x) depending on if you're using the default address, or it's been reconfigured.
Then turn the DHCP server function off.
Connect it to the rest of the network, and you're good to go.
Nov 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
....dead port?...........
Most likely dead port. Probably one of the metal connectors broke, or something internally will be not allowing it to connect or is fried.
Truth is there could be plenty of problems. Though judging with this, I would say its broken.
Jul 12, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link 614 Plus
You need to do some reconfiguration on your router by using the setup cd or by manually configuring it using the user interface of the router.
Apr 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Problems with speed and local ftp on D-LINK DI-524
you may have to open the port that opensuse uses in your routers settings, this will probably be called something similair to virtual servers or within the firewall settings, you will have to enter the port number that the programme uses and allocate the number against the ip address of the pc that is connecting. The fact that you have 3 cards in one pc may confuse matters for the router,so probably dissabling two of them may prove to be another solution to the problem
Jun 04, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-614+ Wireless Router Logo
135 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
