Question about Fuji Cameras
How do i use a FUJIFILM FINEPIX S3280 as a webcam?
I wanted to know if you can use this camera for a webcam, and how you do it. I've seen a couple people saying you can, and i wanted to try it out. Any help?
SOURCE: card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Posted on Mar 09, 2008
  • 3 Answers
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Posted on Jan 08, 2009
SOURCE: Frame full
I had the same problem with a fujifilm camera, the good news is that it's easy to fix. On the shooting menu (press menu when the camera is in shooting mode) there will usually be a set-up option, within that you should see "Frame No." or something similar- the two options for this are either "continuous" or "renew". If you are experiencing the Frame no. full error it means that you are currently set to continuous; TO SOLVE THIS PROBLEM SWITCH THIS SETTING TO RENEW.
Hope this helps!
Posted on May 03, 2009
  • 8 Answers
SOURCE: camera finepix s2000 hd
Ya, the transfer wizard in Windows only gets the pics. For the vids you have to go into MyComputer, and your cam will show as removable media. From this folder, you can copy the vids: they will show no File Type, but the pics do.
If this doesn't work for you, try the Fuji update for Windows and try again:
http://fujifilmusa.com/support/ServiceSupportSoftwareContent.do?dbid=862802&prodcat=878844&sscucatid=664260
Posted on May 11, 2009
  • 4234 Answers
SOURCE: fujifilm finepix f40fd
An update to the initial posting. As a warranty service provider, I can state that physical damage as a result of mis-use is NOT covered under warranty. Lens problems caused by dropping the camera are considered mis-use and are not covered. There is a good posibility that the lens assembly is just out of timing and can be rebuilt, but the cost to do this will not be paid by the manufacturer.
I don't want you to believe that this repair will be for free as it will not.
Regards,
Dan
Posted on Nov 13, 2009
I want to clear all my settings I have accidentally made from my S3280. Is there any easy way to do this?
Hi Susan,
Have a look at the manual (download / view here for free) section on "Setup" that explains how to enter this mode on pg 98. Page 99 has a a RESET command in section "1/5" that should do a lot of what you're after. If not, there's a CUSTOM RESET command on page 100 section 5/5 that will reset settings in "Mode C" (or "Custom Set"). More on Mode C can be found on page 30 of the manual.
May 16, 2012 | Fuji Finepix S3280 14mp Hd Digital Camera...
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
I have a Fugi Finepix JX 250 - I've lost my usb cable and want to download pictures onto my Apple computer. What cable do I need?
Having gone over a month without a reply to my query, I assume my suggestion to use a card reader eliminated the need for a cable.
Aug 05, 2011 | FUJIFILM FinePix JX250 Digital Camera
Can i use my fujifilm finepix as a webcam? and how?
I realize this isn't the answer you wanted to see but, no, you can't use the Finepix as a webcam.
Jul 16, 2010 | Fuji Finepix J100 Digital Camera
Cameras Logo
172 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
