I bought a video signal transmitter to send my paytv to another tv in a different room.Every thing works well except the remote.The remote works well in front of the box not in front of the tv.
  • 1,512 Answers
Hi RUMAC
That's the problem with AV resenders. You cant get the remote back to the box in the other room. There are systems of remote control resender that you can set up to do this for you. It has a receiver in the room you are sending to, and an LED remote picks up the remote control signal then bounces it by UHF radio signal to the other room, and then beams the infrared signal to the front of the to the paytv box from the remote transmitter end.
click here. for an example
This is the type of product I am talking about, available from Jaycar in Australia. I am sure that you would be able to find something the same wherever you are in the world. Any questions, happy to help. A FixYa rating is a great reward for my time to research this for you. Cheers
regards
robotek
Posted on Oct 28, 2008
My Toshiba tv goes to max volume every couple of minuets by itself
Do you have something new in the room that emitts IR signals?
You need to isolate the TV from a possibly rogue IR signal.
Try turning everything off in the room, unplug everything except the TV and Cable box if you are using one.
Turn off all the lights and turn the TV on and select a channel.
Is everything working, is the volume OK?
If you are still experiencing volume issues then this is TV problem and you will need to see a service centre or repair shop.
But if the sound is OK, then you can now start turning things on one at a time to see which device is causing your issue.
It could even be a light that is flickering at just the right frequency to cause your issue.
If it is a CFC or LED light, try a different manufacturer
Nov 04, 2017 | Toshiba Televison & Video
Is there a way to cast screen wirelessly to my Emerson tv model LC195EMX
Amie, There is a way, check links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Best Wireless HDMI Video Transmitter
Send Your Cable TV Signal Wirelessly to Another Room
wireless tv transmitter
How to Watch HD Cable TV service Wireless on 2 TVs works for PS3 XBOX too
Mar 01, 2016 | Emerson Televison & Video
Wifi network not working in some rooms
Change the position of the WiFi router, because there are things like duct work, metal studs and electrical wiring concealed in the walls that can and will have an effect on WiFi signal strength.
Oct 05, 2015 | Linksys Computers & Internet
How do video transmitters work?
A transmitter works by turning the audio/video device it is connected to into a audio and video signal broadcaster. So that when a receiver is connected to another device within range of the transmitter it will be able to pick up the signal from the transmitter and play on this second device. Say you have a TV in the family room and one in your bedroom, if you connect a transmitter to the one in the family room and a receiver to the one in the bedroom they will both be able to receive the same transmission.
Sep 08, 2013 | Televison & Video
I have a martin opener, how does chamberlain work with martin opener
The two brands have different signaling protocols, the OEM remotes send out different signals and have not been compatible. There are Universal two button remotes to allow one remote to control different brand openers. Available at Home Depot etc.
Feb 01, 2013 | liftmaster 371 Remote Transmitter
Memorex MVUC821 TV/DVD. Everything works except the TV.
Just bought the Memorex MVUC821 & the DVD Player will not open using the remote or front panel button!!!
Mar 23, 2010 | Memorex MVUC821 Player
Remote ineffective.
If you have a video camera with a night vision setting, wait until dark, turn out the lights and turn the camera onto night vision and look the the remote. When you press the buttons on the remote does the small led transmitter on the front ligh up. If so the remote is working but possibly sending the incorrect signals.
Jan 22, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Phillips SRU7000 Universal Remote.
i have phillips universal remote that worked just fine until yesterday. my daughter and i were playing a video gae. since then i haven't be able to get remote to work. the little red light comes on up in the corner of the remote and thyere are brand new batteries. help!
al
May 16, 2008 | Philips Televison & Video
Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Apr 13, 2008 | Terk LeapFrog LF30S
Dvd will not play
Hi there. If i understand correctly, you do have the official microsoft DVD dongle and remote ? If so, you might wanna see if the remote is defective. Do you have a camcorder at home ? There is a trick to see if a remote sends it's infrared signals. Put the camcorder on, in a dark room, and put the IR transmitter on the top of the remote in front of the camera. You'll see the IR remote transmitter blinking if you press some buttons. Human eyes can't see it, but the camera does! Try it with another remote that you're sure that works, you'll see. If the microsoft xbox remote doesn't do anything, check batteries, else it's proably defect. If you like to tinker a bit with things, you might wanna open it up to check if there's any cold solder point on it (a broken connection), but you need soldering skills to do so. Else, you'll need a new remote. Hope that helps ! cheebster.
Jul 03, 2007 | Microsoft Xbox Console
48 people viewed this question
 Grubhead
Grubhead
