Question about Saws
Performax miter saw parts
Replacement parts
  • 10865 Answers
SOURCE: Craftsman 10 inch miter saw, handle broke
I would reattach it with epoxy. Go to the hardware store with the handle and let the clerk help you pick out the best epoxy for the job.
Posted on Mar 18, 2009
  • 199 Answers
SOURCE: replacement part not available
I had the same problem and the parts are available but they are expensive. There isa spring loaded double contact switch. Take it apart. You will have to drill the rivets out and reassemble with some sheet metal screws or machine screws and nuts. Careful when you open because the parts may fall out. You will want to know how it is built. Usually only one contact goes bad so hard wire the side without continuity(solder together & heat shrink or black tape). The rest is just good mechanical inclination. You will figure it out.
Posted on Jul 05, 2009
  • 384 Answers
SOURCE: craftsman radial arm miter saw parts discontinued
Any hardware or home improvement store will have a replacement.
Posted on Jul 22, 2009
  • 583 Answers
SOURCE: I bought a used dw708 miter saw. It makes an
i would think it is neccesary to strip it down, but obviously there are bearings gone allowing the shaft to move over and grind and screech,i think it will be all too obvious what you will need when she is stripped ,.
Posted on Aug 27, 2009
Testimonial: "Right on the money. The front bearing was mostly gone. Thank you."
jyackle5
  • 8197 Answers
SOURCE: In what order and position
Try this link to see if it will help you put the guard back on.
http://www.makita.com/en-us/Assets/Output/DownloadFile.aspx?FileName=Products/_PartsBreakdowns/PB_LS1011N.pdf
Posted on Jan 22, 2011
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
Find manual for performax table saw 90215 my fence is broke
I have attached a link to a PDF file of the manual for the Performax.
http://www.menards.com/main/store/20090519001/items/media/Hardware/performax_logo/Install_Instruct/12-0110_240-3600.pdf
On another note, if this does not help you can call:
For questions / comments, technical assistance or repair parts -
Please Call Toll Free at: 1-866-858-2664 (M-F 8am - 6pm)
Dec 25, 2014 | Saws
The belt on my new saw started to frey after some use
It sounds like you need to replace the belt. try the following websites, they offer the saw parts:
http://www.ereplacementparts.com/bosch-5312-dualbevel-slide-miter-saw-parts-c-128_1090_157465.html
http://www.toolpartspro.com/bosch-parts/bosch-5312-parts.html
Feb 10, 2013 | Bosch 5312
Nee the instruction manual for the dewalt dw718 compound miter
You can grab the manual and any replacement parts or accessories that should of came with it from eReplacementParts.com - They are DeWALTs supplier for manuals, parts, accessories, and tools online.
Apr 11, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Saws Logo
829 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
