Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Whirlpool reset Dishwasher GU3200
Timer stuck at 63
5 Suggested Answers
  • 14 Answers
SOURCE: whirlpool GU3200 dishwasher
The illusive technical repair sheet that isn't there...
Turn the thing a little further and pull UP. It'll come out. You've got to put some muscle into it!
The manual for the GU1000/1200/1500 is here (it's almost the same and as close as I can get you to a 3200)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Jeremy
Posted on Dec 29, 2007
Blessedbygod
  • 85 Answers
SOURCE: Whirlpool dishwasher GU2400XTP stalls during cycle
Sounds as if you have a faulty timer. These should be covered under warranty. Check you documents for duration of warranty.
Posted on Dec 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool dishwasher gu2700xtsqI does not cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
heatman101
  • 43501 Answers
SOURCE: Our whirlpool dishwasher, gu3200 is leaving food
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 27, 2011
Mod DP1040XTXQ6 clean light does not come on
If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board
God bless you use the VOM..
Apr 05, 2013 | Whirlpool DP1040XTX Portable Dishwasher
Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control 10_17_2012_1_06_02_pm.jpg
Oct 16, 2012 | Whirlpool Dishwashers
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
How do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Apr 22, 2012 | Dishwashers
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Our whirlpool dishwasher, gu3200 is leaving food residue on the dishes. We have taken it apart, cleaned everything, rinsed it with vinegar and the arms are rotating...yes the problem still persists. Any...
heatman101
Jan 22, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Nov 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU3200 dishwasher
Jeremy
Nov 23, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
66 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
