Question about SanDisk Sansa m230 MP3 Player
Problem with drag and drop
I can no longer drag and drop mp3 files from a folder on my computer into the sansa m230. It has worked in the past but now I get the message "Error Copying File - Cannot copy *.mp3: The device has either stopped responding or has been disconnected.". It may be worth mentioning that it is possible to transfer files using Windows Media Player. I have tried rebooting and using different usb ports with no success. Any help would be most appreciated. Tim Marshall
(FOUND THIS SOLOUTION ON AFTERDAWN.COM) The problem is that this player have 2 standards for connecting to PC. One is MSC and other is MTP. Each one have different directories structure. If you put music when your player is connected as MSC, when you will conect as MTP you'll be not able to see the files uploaded previous. The same case is available when you write music files as MTP=> you can't see these files in MSC mode. So, set USB mode of your Sansa as MCS, power off, put hold switch to lock and connect to PC. You will see 3 directories: Audible, Records and Config (or something like that). See if your "invisible" music files are here. If they aren't connect as MTP. To connect as MTP: set USB mode to auto, shut down Sansa mp3 player, put hold switch to unlock and connect to PC. You will see only 2 directories now. Media and "something" (I can't remember now). Look for your "invisible" files and do what you want. MTP mode is for use with newer PC's. I advice you to use MCS mode all the time because is compatible with any PC (old or new). Good luck!
Posted on Jan 01, 2007
How do i get music on to my sansa clip+?
Loading Music
You can transfer music from your computer to the Sansa® MP3 player using the drag-and-drop method or using music management software like Windows Media Player.
Drag and Drop (Windows)
Follow these steps to drag-and-drop music to your Sansa® Clip+ MP3 player:
1.
Connect your Sansa® Clip+ player to your PC.
2.
Select Open device to view files using Windows Explorer on initial connection or by going to My Computer.
3.
Double-click on the Sansa Clip+ MP3 player.
4.
Double-click on Internal Memory.
5.
Double-click on the Music folder.
6.
Drag and drop music files from your computer to the Sansa® MP3 player’s Music folder.
You can also drag and drop files to a microSD™ card inside your player by going to My Computer > Sansa Clip+ > External uSD Card.
Feb 07, 2010 | SanDisk Sansa Clip MP3 Player
Sansa m230 not syncing music files or downloading them. Process leaves the Sansa m230 with 0 files and i am finding it impossible to load new file(s) ?
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then add music this way and see if it is works: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 01, 2009 | SanDisk Sansa m230 MP3 Player
Just got my computer back from shop and i can`t put songs on M230
Check to make sure you stll have your driver for the player on your computer. If that does not work try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. After doing this if you still cant add music on your player try loading it this way: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Dowloading
plug it into your computer with the included usb cable, go into my computer and select sansa m230 and drag and drop music that you have on your computer onto the player. you can also sync your music if you use windows media player.
Jul 24, 2008 | SanDisk Sansa m230 MP3 Player
Im trying to copy music from my sandisk sansa m230 onto my windows
You can open the device under COMPUTER>Device Name (m230)
Open the MUSIC folder and just copy the contents to your computer by dragging and dropping them onto your desktop, or other location.
Best of Luck.
Nov 02, 2007 | SanDisk Sansa m230 MP3 Player
Cannot see m230 songs from My Computer
Check your WMP configuration, so that it will display Mp3 files
Oct 16, 2007 | SanDisk Sansa m230 MP3 Player
Downloading files from mp3 players
If the files are not on the PC, Windows Media Player will not see them. You can manually manage the music from My Computer. Double-click on the device name Sansa m230 and you can see the files and folder. You can just drag and drop these onto your computer to save them. You might also want to format the device to remove everything and give you a clean slate. Right Click on Sansa m230 and select format. Best of Luck.
Oct 09, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230
How did you transfer the music? If they are not viewable on the device, you might try updating the firmware. Otherwise, I would format the device and drag and drop the files manually thru My Computer. * format - right click on the device in My Computer, and select format
Sep 10, 2007 | SanDisk Sansa m230 MP3 Player
Sandisc m230
I dont usually mess around with real player when you dl or put your music on your computer put a shared folder in there and put all your music in there and then when you connect your mp3 player go to your shared folder and right click on the song when it comes up go to send to and it will give you a list it will say what ever you mp3 player is named and if you click that it will put your music on your mp3 player and if you couyld upgrade to at least a widows xp ~Grim
Apr 17, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
142 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
