Question about Sony Cyber-Shot DSC-T1 Digital Camera
My sony cybershot wont turn on!!
My camera turned off in the middle of taking pictures. So I charged it for about 4 hours,put the battery in and pushed the power button,and it chimes on and goes right back off. Please help me fix this problem:)
  • Sony Master
  • 4,738 Answers
The symptoms sound like a failing battery. The camera is shutting down due to insufficient power during startup checks. How old is your battery? Rechargeables really aren't meant to last more than a year or two.
Now I realize that Sony batteries are outrageously expensive. But thankfully there are generic alternatives such as:
http://www.amazon.com/CTA-Digital-DB-FT1-Rechargeable-Equivalent/dp/B0006JMJPY/ref=sr_1_4?ie=UTF8&s=electronics&qid=1225553784&sr=1-4
Posted on Nov 01, 2008
My sony cybershot wont turn on but has not been dropped, what may be the cause of this?
You seems to have a bigger issue than anyone can offer advice on this website. Consider taking your camera to a service centre for professional diagnosis and if possible a fix on your camera.
Sep 06, 2014 | Sony Cyber-shot DSC-WX60 16.2 Megapixel...
I have a sony cybershot dsc w120 camera and it turns on and maybe lets me take 1 or 2 pictures before shutting off (sometimes with the lens still out). It hasn't been dropped or exposed to water, so I
Things to check first for a camera that won't turn on, or works intermittently are the battery contact points, ensuring that they're clean, and making good contact with the battery. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 23, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
I have a sony cybershot and the backlight wont turn on
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Charging batteries
Hi Ava, thanks for coming to FixYa.
It is not good to leave your battery on the charger longer than 2 hours. Depening on your battery type, it should not take longer than 2 hours to charge up.
If you leave it on longer than that, it will get too hot, and might make a fire hazard. Also, the hotter the battery gets, it lessens the life of the battery.
Most battery chargers will not automatically turn off, so you should monitor the charging time.
Thanks for coming to FixYa. If you have any other questions, you can leave me a comment.
Namaste
Rob
Mar 25, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Sony cybershot dsc-s90
Hey Gregorious03,
You could try removing the batteries for at least one minute and then reinserting them, or you could try initializing the camera back to the factory settings under the setup menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony cybershot DSC-W50 lens problen
thats normal.
it just doesn't have enough power to bring the lense back in.
once you charge your battery and turn it on the lense will automatically come back in and then out for you to take a picture.
Apr 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Power won't stay on
camera needs to be reset...but not gonna be easy
take batteries out...hold down power switch for 15 seconds...then put batteries in and restart
if camera works...go straight to menu and reintialize all functions
this is a firmware/software problem that is not easily fixed...and Sony wants $91 to fix a $100 camera
keep repeating this until it works...may take numerous attempts...but this is how I got my camera running again
Mar 27, 2008 | Sony Cybershot S650 Digital Camera
The power wont come on
when i turn on the camera is beeps then turns off with brand new batteries. it does the same when i plug it into the computer. I press power it says cyber shot then turns off. i know batteries are not the problem, what is?
Dec 28, 2007 | Sony Cybershot S650 Digital Camera
Sony Cybershot
Turning on may have killed it. however try this. Take the batteries and card out and leave the doors open Take a polythene bag and place in it a quantity of uncooked rice or salt tied into a suitable cloth. put the camera in and seal the bag. leave in a warm dry place for several days This may save it -or it may not.
Aug 02, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
138 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
