Question about Behringer Audio Players & Recorders
My behringer c1-u makes a humming sound all the time also crackling noises, but the crackling only occurs with voice, not instrumental :S
At first i thought it was the recording system so i changed from an adobe software to audacity the humming continued and now there is a crackling sound too :S project rate at 44000 hz
SOURCE: Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Posted on Jan 23, 2008
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
robotek
  • 1512 Answers
SOURCE: No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
Posted on Jul 04, 2008
  • 13 Answers
SOURCE: C1 Microphone noises
This is a common problem with less expensive condenser mics, due to contamination on the circuit board or capsule there can be some leakage current which makes noises and can cut off the sound entirely. SP should be able to fix this for you for not much money.
Posted on Nov 30, 2008
JSEhandyman
  • 368 Answers
SOURCE: crackling sound
You need to look inside (through the front grill) with the lights turned off, and try to spot the sparking/arcing high-voltage - - what you're likely hearing is a spark where high-voltage is grounding-out due to a fault in the wire insulation or some other insulating structure.
Once you isolate where in the machine it's arcing, you may be able to determine where it is and whether or not it's within your skills to fix it. If it's an XL-15 as indicated by this category, it's no longer in warranty (no longer even supported by the manufacturer, for that matter, so it will be up to you to determine how much you want to work with high-voltage electricity.
If you can find the spark, you might be able to report back here for more detailed advice. Hope this helps.
Posted on Dec 23, 2008
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
Oct 28, 2016 | In Microwave Ovens
How do i use my behringer nr300
Hi Paul
Here's the link to your user's manual.
I hope this gives you an idea of where to start.
-Steve
http://www.behringer.com/assets/NR300_P0595_M_EN.pdf
Jan 19, 2015 | Behringer NR300 Noise Reducer
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
Crackle sound
dirty slide switch/rotary pot. clean with contact cleaner or wd40
Feb 20, 2014 | Behringer Xenyx 1204USB USB Mixer
The speakers are making a crackling noise that is not effected by the volume
Check the speakers first. If the voice coil of the speaker has any fault, the speaker should be replaced. Connect an other speaker in place of present one, and see whether the crackling sound occurs with it too. If yes, the audio output board to your TV have the fault, and it should be replaced.
Oct 17, 2012 | Mitsubishi LT-46153 LCD TV
Vox ac30cc2x fault finding
Check valve you replaced has made proper contact in socket. Plug it in and out a few times to clean pins. Is inteference/crackling noise there when volume is turned down to minimum. This should tell you whether the problem lies before or after the volume control. A good clean can solve many faults. Servisol on pots works wonders.
Ian
Jul 24, 2012 | Radio Communications
I have Behinger Europort EPA900, One speaker crackles, tried swopping cables etc, but nothing helps, the problem seems to be definitely with the speaker.
Open the speaker and look for loose connections. Carefully move cone with fingers. If there is noise when doing so...rubbing type noise, speaker needs reconing or replacing. If the crackling comes from teh tweeter section, then the tweeter may need replacing.
Jan 31, 2011 | Behringer Europort EPA900 Ultra compact...
My behringer b203a is making a loud muffle mono feedback sound when i am trying to use it. what could be the problem? please help!
this is normaly a wiring or amp issue. if it was the speakers they wouldnt make any sound or they would crackle or buzz
Jan 31, 2011 | Behringer B3031A 2-Way Active Studio...
465 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
