Question about Fuji FinePix S5000 Digital Camera
Fujifilm s5000 blank screen
Turn camera on, take off lens cover, screen is black
poolseman
  • 206 Answers
SOURCE: fuji s5000
CCD sensor faulty ( sits behind the lens inside and this device converts light into image ) . If the camera has not been abused the repair ought to be done free of charge because properly manufactured CCD or CMOS unit should last 15 years !
Posted on Aug 29, 2007
pauman
  • 248 Answers
SOURCE: Fujifilm Finepix S5000
the problem might be inside. when cameras are dropped cable connections inside loosen. try to bring it to your local camera specialist and have it checked. if you open it yourself it might cause more damage.
Posted on Jun 19, 2008
  • 11967 Answers
SOURCE: Hello my barely used fujifilm fine pix J38 camera zoom error mess
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
  • 275 Answers
SOURCE: FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
Posted on May 24, 2010
  • 73 Answers
SOURCE: turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Posted on Jul 25, 2010
My view screen is white but I am able to view my pictures on my memory card
Most likely a dead CCD (imager) unit. Happens to these cameras. Usually they are supplied with the lens and are expensive if ordered from Fujifilm - could be about $200-300. I wouldn't recommend using used parts because they could break down again sooner or later. I suggest you buy a new camera.
I have worked for Fujifilm.
Tom
Mar 05, 2011 | Fuji FinePix S5000 Digital Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
My fujifilm s5000 has purple lines coming up on the screen and when i take a photo. what could be wrong and is it easily fixed?i need to get it fixed as i cannot afford a new 1
If the purple lines only appear when you point the lens INTO the sun or light source, that would be why they appear in the photo. If you have the sun/light source behind you and the purple lines still appear on the screen and in the photo, it's time to get a new camera.
Aug 19, 2009 | Fuji FinePix S5000 Digital Camera
Fujifilm S5000 !hand error
It it in normal shooting mode? The hand means the shutter speed is too slow to hand hold the camera.
Jul 24, 2009 | Fuji FinePix S5000 Digital Camera
Fujipix S5000 screen is all white
I just started having the same problem with my S5000, also.
Jul 11, 2009 | Fuji FinePix S5700 Digital Camera
I have a fujifilm finepix S5000 when camera is turned on it just shows a white screen. Cant take pictures, movies, nuffin works. Can u help, please.
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 09, 2009 | Fuji FinePix S5100 Digital Camera
Can't see image in viewfinder or on lcd screen.
Bad CCD.
See if Fuji have Service Bulletin and will fix it for free under Lemon Law.
Mar 18, 2009 | Fuji FinePix S5000 Digital Camera
S5000 fujifilm
Was probably caused by the zoom carriage locking on power out due to batteries running low. Turn off camera, tap barrel with solid but non-metallic object and turn on. Did this two times and it worked for me on second.
Oct 16, 2008 | Fuji FinePix S5000 Digital Camera
Change from black and white to color
There is a little blue button next to the LCD button, directly above the display screen. There are alot of controls when you press, like color, B&W, shutter speed, etc. Thanks
Sep 29, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
174 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
