I need to find out how to repair a laptop hard drive to make it detectable again. I bought one on ebay but it was damaged in the post. How can I save money by making it detectable again? My dell laptop cannot detect it (there is no prob with the laptop itself)(tested it)
Comments:
Oct 13, 2006
- I have since found that Dell (being awkward folk) require an interface adaptor to be between the hard drive and the laptop. Standard 2.5" IDE actually does not fit the laptop's internal connector. A special connector must also be purchased. Having now done this I have found it works fine.
-   I believe I have the same issue. I just purchased a new hard drive and my Inspiration 1150 is not seeing the drive. Where do you get the connector?-   katcar
Unfortunately, you have to have the hard drive installed and running to do a manufacturer on line test, or if you have a usb cable with a 2.5" adapter on other end to connect to a pc to see if it runs or is readable.
Not all hardrives work in all laptops, try to fit same make as removed if you already have'nt.
Although, why keep something that was damaged in the post, try for a return.
Comments:
Oct 13, 2006
- As long as your up 'n' running, great stuff! ;-D
my ibm thinkpad t20 pc **tebook was working great and all of a sudden im getting a message that says operating system **t found, hard drive **t installed, re-install hard drive. i have ** idea how to correct this problem. can you help? thanks
Comments:
Mar 09, 2008
- ok. if i hook a usb cable from my hp pavilion to my not working ibm thinkpad t20 notebook, then what do i do?
My laptop will not boot. When the power button is pressed, the light flickers on and off for about...
(More)
My laptop will not boot. When the power button is pressed, the light flickers on and off for about 10 seconds, but there are no audible indications that the HD or fan turn on. I have tried reseating the RAM and HD, turning it on using battery only, AC power only and both, but with no change.
