Question about Bowflex Treadclimber
Tread climber tc 6000
Walking belt
3 Suggested Answers
bugoy31
  • 1238 Answers
SOURCE: Assembled Bowflex Tread climber yesterday. Getting
Good day!
What is the model # of your Bowflex?
Posted on May 22, 2011
ercupa190
  • 12223 Answers
SOURCE: MY TREAD CLIMBER STARTS THEN STOPS AND FLASHES E1
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
Watch this videos and tip.
You must concluded if the inclination motor is faulty or Main Motor Controller Board is faulty.
Posted on Nov 22, 2011
Tread climber tc 5500. Error code 6,0,0,
Hi normally this error is
trouble with the incline motor
Test the motor with 110vac forward and backward
see the schematic diagram, with DMM and see t
The power of the Incline Motor Assembly Part1
Let me know
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 25, 2018 | Exercise & Fitness
What would be the problem if led lights f and h are not lit?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 24, 2016 | Bowflex Tc5000 Climber Treadclimber...
Why does my Bowflex TC5000 cut out?
If you're running the machine on a dedicated circuit then your unit is drawing too much current. This can be caused by friction and drag. Solution: Lube deck/belt. If problem persists, replace deck/belt. If you ignore this fix this will blow your controller. .
Apr 29, 2014 | Bowflex Tc5000 Climber Treadclimber...
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
Start shuts down machine and blows circuit breaker
see the video attached. and proceed according. However you must test the power cord for short circuit. some wires is touching each to another. Or the outlet wall the wires are loosing touching each to other and blowing the c.breaker, or call some electrician for to fix it.
God bless you
Oct 17, 2013 | Bowflex Tc5000 Climber Treadclimber...
How to lubricate tc500
Nice machine! I use WD 40 on my machine. It comes with a small tube attached to the can that lets you get into joints and bearings easily. Keep the can handy if you work out regularly..it keeps it quiet and smooth!
Jan 12, 2013 | Bowflex Tc5000 Climber Treadclimber...
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
Bowflex Treadclimber Logo
24 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
