Question about Sony Walkman D-EJ361 Personal CD Player
Installing the CDwalkman cover and springs
My CD walkman fell down and cover and little springs separated from walkman. No any piece is broken. How to install the cover with springs? I have Sony D-EJ361.
0 characters
1 Points
Seeking user manual for Sony CD Walkman D- NE050
Jun 26, 2011 | Sony Walkman D-NE050PS Personal CD Player
SONY Walkman D-NE005 won't play my CDs I am getting a "no disc" message
you may need to contact Sony Support. You're lucky if its still covered by the warranty.
Oct 14, 2010 | Sony Walkman D-NE300 Personal CD Player
Hold the sound button for a few seconds (the button that boosts the bass depending on which model walkman)!!!!   That should do it.....
Jul 22, 2008 | Sony Walkman D-CJ01 Personal CD Player
In hold mode
There's a little slider button on the bottom of the cd player. I'd forgotten it was there until I was looking for something else.
Hope it's as simple as this! Good Luck!
Apr 28, 2008 | Sony Walkman D-EJ360 Personal CD Player
I have a durabrand cd model # cd-896
Just try googling. "Duraband Cd-896 Spare parts"
Or you can look around the house and steal abother one from somewhere, like your roommates walkman. =p
Dec 21, 2007 | Durabrand Anti-Skip CD-895 Personal CD...
Sony Walkman D-NE004
I assume you've tried batteries, cleaned the laser, etc. If so, then the laser might be knackered!
Nov 20, 2007 | Sony Walkman D-EJ360 Personal CD Player
Blinking "disc" error
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Nov 01, 2006 | Sony Walkman D-EJ100 Personal CD Player
How to put the spring in
are you saying the spring to the door fell out and this is the second time??? how was it replaced the first time as a spring should not just fallout unless its dropped and a boss is broken off. ( a boss is a small plastic piece that would hold the spring in place.) This is a hard call unless you get the mechanical diagram as I dont have and they are all made differantly.
Mar 24, 2006 | Panasonic SL-SX430 Personal CD Player
Sony Walkman D-EJ361 Personal CD Player Logo
24 people viewed this question
Top Sony Personal CD Players Experts
isaac johny
isaac johny
Are you a Sony Personal CD Player Expert? Answer questions, earn points and help others
