Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag MAV6000AWQ won't spin
Everything works fine, except the machine will only spin on the DELICATE cycle.
  • john8591222 Dec 29, 2008
    same thing
  • Anonymous Jan 29, 2009
    maytag is ****. I have had nothing but problems with this washer. baring, pump and now not draining. sorry product - I will never buy another Maytag product.
My maytag atlantis does not spin fast enough to get all the water out.
Posted on Dec 06, 2008
I have a maytag frontload washer 2000 series that will not start spin cycle won't even try unless the washer is empty. no error codes showing, even after I do diagnostics. help...wife is miffed..
After determining that the washer is plugged in, the drain hose is free from kinks, the "No spin" option is not selected and the washer door is securely closed, the cycle should be reselected to see if the washer will spin. If this does not solve the problem, it is advised to contact a trusted repair service. Problems with the lid switch assembly, drive belt, drive pulley, drive motor, tub bearing or transmission can also cause a Maytag washer not to spin. These repairs should be carried out by a professional.
If the washer is spinning but clothes are still wet at the end of the cycle, one should ensure that the washer is not overloaded or unbalanced and that the correct wash cycle is selected. Delicate or handwash cycles spin at a lower speed, resulting in wetter clothes
Oct 12, 2016 | Maytag Washing Machines
My Maytag Washer won't drain or spin
Inside the main control switch has many studs of plastic. They get worn out and don't work. See if it works on a different cycle like delicate. No work; then you need a new control switch. Either way you need a new control knob switch!
Nov 09, 2012 | Maytag Washing Machines
Maytag MAV6000 Top Load Washing Machine
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Nov 07, 2008 | Maytag Atlantis MAV6000 Top Load Washer
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Mav6000awq
well..that would certainly make it sound better. you might want to check the bearings and belts first though..
Mar 10, 2008 | Maytag MAV3855A Top Load Washer
Maytag Washer mav6000awq
not even water going into unit???? with power to the unit you should at least get water into it at very least,
Feb 25, 2008 | Maytag MAV3855A Top Load Washer
MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Apr 04, 2007 | Maytag MAV3855A Top Load Washer
Washer just fills up and that is it
Sounds like a winding on the motor is burned out or the timer is defective. The motor uses a low power circuit during the delicate cycle both during wash and spin. The timer selects which winding is energized (fast or slow).
Feb 05, 2007 | Maytag LAT3600A Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
339 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
